New Roof Weather Seal...Too Thick
Discussion in 'Body Restoration' started by GoldenOne7710, Nov 9, 2019.
  1. GoldenOne7710
    4,825
    419
    Jun 23, 2004
    Athens, GA
    I installed this Metro roof/door seal back in August. Doors were extremely tight and difficult to close...but I got them closed and they've been closed since Aug 31st. A couple of weekends ago, the painter goes over to do the final adjustment on the door glass, door striker, etc.
    This end portion of the roof seal is extremely thick and it is what is giving the most resistance of allowing the doors to shut.
    The glass is adjusted as far back as they can safety be without hitting the trim at the rear of the door jam.
  2. GoldenOne7710
    4,825
    419
    Jun 23, 2004
    Athens, GA
    Here are the orginal GM seals I took off. They are MUCH thinner at the specific contact point.
    So what would be the easiest remedy for this? Remove some of the material on the underside? Apply heat while in the closed position to "force" it to take shape? Parking out side in the sun isn't an option at this point.
  3. COPO
    17,882
    754
    That’s aftermarket crap for ya. I guess no one can do it right. Here is mine I bought from GM in 1985 for my 70 Z28.
    0EAC5BF6-1AED-4DE8-B964-4E3FD1CED9AE.jpeg 443AD8EF-E16D-4F4C-A6DF-4675C99A182D.jpeg
  4. badazz81z28
    16,923
    502
    Las Vegas, NV
    Soff seal...give the a try or Steele
  5. Chuck71RS
    1,477
    187
    Nov 24, 2012
    Houston, Texas
    I used Metro. They were to thick at the front end as you described but I used a curved wood shape tool to remove material. The windows finally rolled all the up for a tight fit along the top
    GoldenOne7710 likes this.
  6. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    Soffseal on top, Metro on bottom is the only thing that worked for me. The replacement GM weatherstrip isn’t good anymore either, if you can even find it.
  7. GoldenOne7710
    4,825
    419
    Jun 23, 2004
    Athens, GA
    I did some digging and see where you've said this before. If I have to buy Soffseal anyway, I may try to remove some material on the underside (that isn't seen) to attempt a better fit before I buy anything else. If I screw it up...I would have to replace it regardless. If it works...it works...and saves me $$$$.
    jthomas likes this.
  8. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    Nothing wrong with that plan. Metro looks really good up top so if you can trim it to fit it’s worth a try. I will say though, it’s tough to trim rubber seal if you use sandpaper or other abrasives. A knife works well, but it’s easy to over trim. Give it a try and let us know how you make out. Hoping it solves the problem for you.
  9. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,698
    17
    Jul 31, 2001
    Ft. Lauderdale, FL
    I bit the bullet and ended up with GM roof rail seals They were WAY expensive. But my doors closed fine after, and the actual material that they're made from is much more squishy and forgiving when you go to align and seal the window gaps.......for real.....
  10. GoldenOne7710
    4,825
    419
    Jun 23, 2004
    Athens, GA
    I brought both the originals and the Metro I just tried with me to work today. About to stop by Year One and compare the Soffseal brand since they have it. I'll be able to compare all 3 at the counter.
    75Motion likes this.
