New Rotors?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Camaromurph, Nov 30, 2019.
  1. Camaromurph
    Camaromurph Veteran Member
    116
    47
    Oct 20, 2018
    Naperville, IL
    Another question. The new rotors came with bearing races installed. I also bought new bearings that came with races. Do I need to remove the races in the new hubs and replace with the ones that came with the bearings?
  2. Camaromurph
    116
    47
    Oct 20, 2018
    Naperville, IL
    Should have read my own thread.
    COPO - see you did this in your original reply.
  3. COPO
    18,411
    1,067
    Keep the races in the rotors. Now you have spares in the box as I do.
  4. badazz81z28
    17,406
    605
    Alabama
    I personally like to keep sets together especially if your using a higher quality bearing. I would swap the races out. You’ll never need a spare set of races.
    jthomas likes this.
  5. Skip Fix
    Skip Fix Veteran Member
    2,193
    24
    Mar 21, 2007
    Katy,Texas
    "personally like to keep sets together especially if your using a higher quality bearing. I would swap the races out. You’ll never need a spare set of races." Especially since most rotors are Chinese now.
  6. COPO
    18,411
    1,067
  7. mallard
    mallard Veteran Member
    657
    150
    Oct 3, 2013
    SK, Canada
    Agreed. I’ve been out of the MVMR trade nearly 40 years and even back then we also gave all new rotors & drums a very small cut. Otherwise you might get a small pulsation.
  8. roeville
    roeville Veteran Member
    1,260
    103
    Oct 9, 2000
    SF East Bay CA
    Having worked many years in specialty gear shops and bearing WD’s, I can tell you that we sold many bearing cones with or without the races, and also as sets. Bearing cones were always available individually because some part numbers can match with more than one race (different O.D.). Never had a customer complain about cones not mating with cups unless the part number was wrong.
  9. COPO
    18,411
    1,067
    I’ve bought new hub/rotors for the Camaro and Grand Nat’l and never ever had an out of round rotor or vibration out of the box. I bought an AC Delco hub/rotor from GM Parts back in 2002 and had no problems.
  10. biker
    biker Veteran Member
    1,174
    163
    Dec 7, 2014
    New Liskeard Ontario Canada
    Even in the early 80's, new drums and rotors were out just a small bit. Not noticeable most times on the car, but definitely could see them out a few thou on the brake lathe. Sometimes way more. Service manager at a dealership where I did a work placement would always true up new ones if they were going on a picky customers car.
