New Shocks?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Paul Calland, Jan 10, 2020.
  1. Paul Calland
    Paul Calland New Member
    Nov 20, 2019
    Hey all,
    I'm in need of new shocks for my 79 z28 and am not savvy when it comes to suspension work. I know engine weight is a factor when it comes to replacing them...? So I figured I'd provide my engine type if that helps. I have a 350 sbc built out to a 383 stroker! Please let me know what the best option is for my car! Preferably not to expensive either! Thanks!
  2. COPO
    18,440
    1,076
    I went to an AC Delco store and bought gas cushioned shocks for my 70 Z28 and they are great and guaranteed for life to the original purchaser. Been on my car since about 1990. Previous to these I had Koni’s and both rears were shot after 8 yrs.
    Paul Calland likes this.
  3. CorkyE
    10,547
    551
    What is your suspension setup and what do you want to do? For a street car, you can't go wrong with AC Delco, something near stock. With my original rubber suspension, I had good luck with Monroe Gas-Matic shocks. Now I'm lowered a bit, solid body bushings, delrin bushings all around, using Koni reds.
  4. Zspoiler
    Zspoiler Veteran Member
    3,375
    277
    May 6, 2012
    Federal Way, Washington
    Is the car stock and are there any plans for upgrades. I have used KYBs Konis .Carrea shocks over the years .Alot depends on your budget as well .Good luck to you.
  5. berg2695
    berg2695 Veteran Member
    298
    59
    Nov 13, 2011
    AUBURN, WA
    For what it's worth, I'm pretty sure GABRIEL makes shocks for AC. They tend to be a little less expensive but I think they are identical. I.E. : AC DELCO Professional = GABRIEL Ultrashock. Check out RockAuto.
    Zstar likes this.
  6. camaro lover
    camaro lover Veteran Member
    449
    26
    Dec 29, 2002
    Owen Sound, Ont, Canada
    I bought ac delco. I'm in canada. Not sure where your location is but I found Amazon was $50 less then my local parts place.
  7. Zstar
    Zstar Veteran Member
    1,576
    342
    Mar 23, 2014
    Ocala, Florida
    Gabriel Ultrashock, you won't be sorry.
