New springs 15x10 and 15x8 295/50r15 PICS
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Jaxons nasty z, Jan 17, 2020.
  1. Jaxons nasty z
    Jaxons nasty z New Member
    25
    Dec 25, 2019
    midwest
    I replace front springs 350lb and rear leafs 2" lift from st louis spring . got 10" and 8" ar wheels were cheap @ $120 ea $110 ea . 4" bs. i had the 295s and when i can im going with the sportsman 28x12-15 because of the 4;11 i need the height . Everything ontop is GM Performance aluminum including the roller rockers and water pump . Heres the pics of my 79 with built 350 bw st10 and 4;11 and 4th gen seats . before pics of it lowered with cut springs and black wheels , yuk .
    dave@ztech likes this.
  2. cadillac_al
    cadillac_al Veteran Member
    847
    89
    Apr 22, 2015
    Maine
    I like the improvement. It looks like a 70's hot rod. Oh, yeah, it is a 70's hot rod. :)
  3. Jaxons nasty z
    25
    Dec 25, 2019
    midwest
    I am 58 and thats the way i grew up . big wheels gears louvers and girls. I miss superman , should have never got rid of him! .
  4. 1978 Z/28
    1978 Z/28 Veteran Member Gold Member
    106
    28
    Jul 17, 2017
    New Brunswick
    I also like the look,
  5. mrfleet12
    mrfleet12 Veteran Member
    354
    111
    Aug 8, 2014
    West of Chicago IL
    Looks good, I have those exact seats sitting on the bench in the garage.
    How did you mount them?
  6. biker
    biker Veteran Member
    992
    113
    Dec 7, 2014
    New Liskeard Ontario Canada
    Nice work! Big difference, great looking car.
  7. Jaxons nasty z
    25
    Dec 25, 2019
    midwest
    I used my original tracks . Bolted front on to seat then drilled hole right in front of back holes in seat and bolted the tracks to floor . I did use big washers and longer bolts to adjust the fronts up higher and not as many in back to raise the back . At 5”11 my head was real close to headliner but now i have a solid 3” - 4” probably headroom .
    mrfleet12 likes this.
  8. Jaxons nasty z
    25
    Dec 25, 2019
    midwest
    Her is a pic . I added 2 under each track when i did driver seat . Heres a pic
  9. Jaxons nasty z
    25
    Dec 25, 2019
    midwest
    I did buy the green hardend bolts to hold them to the floor
  10. Jaxons nasty z
    25
    Dec 25, 2019
    midwest
    Heres more pics
