New to the forum with a 1971 Z28
Discussion in '1970 - 1973 Specific' started by newtodu06, Aug 20, 2019.
  1. newtodu06
    newtodu06 New Member
    21
    Jul 22, 2015
    Raleigh, NC
    I've been on this site for a number of years because I always had a fondness for old Camaro's. I've owned 2 back in the 70's and just recently purchased a numbers matching 1971 Z28. As far as I can tell, it was a well maintained California Z, with correct heads, carb, intake, body features, etc. I'll be on here asking questions and getting advice in the future, please bear with this old man with a young heart for these cars.
    The first thing I noticed with the Z is I have an issue with the secondaries not opening up when they should. On a recent drive, I mashed down on the gas, and found the gas pedal rod was being 'blocked' by the existing carpet on the floor pan. After checking out some stuff, I noticed the gas pedal pad was missing, and I think the angle of the rod is not far enough away from the floor pan. I have to look under the carpet to see if the pins for the floor mounted pedal are there, but my guess is they are not there because the floor pans are new, so one project is to decide if I want to hang the gas pedal, or attach it to the floor like it should be. My question is this: Has anyone needed to bend the gas pedal rod to get it farther away from the floor pan? Is that normal?
  2. x77-69z28
    x77-69z28 Veteran Member
    321
    27
    Feb 5, 2010
    long island, new york
    That is the correct set up for the floor mounted gas pedal. Should be an easy fix. It is one of the identifiers of the 70-71 Z28’s. It is covered in the assembly manual. It will eliminate any question that your car is in fact a Z. I would look twice at a Z without a floor mounted gas pedal. Just my .02.
    newtodu06 likes this.
  3. l16pilot
    1,813
    130
    Dec 13, 2004
    Hurlock, MD, USA
    Welcome to the forum and congrats on your purchase. As Buddy mentioned, adjusting (bending) the throttle rod is not difficult to get the extra travel needed, but there may be other issues at play. For example, does your car have the correct throttle cable?...a slightly longer cable would produce the same results and is the cable connected to the correct hole on the carburetor throttle arm? Using the wrong hole on the carb throttle arm could also result in the condition reported.
    Personally, I would keep the floor mounted set-up..part of what made the 70-71 Z28s unique.
    gpm6367 and newtodu06 like this.
  4. Twisted_Metal
    26,818
    875
    The correct pedal is fairly easy to find.
    The floor bracket with the studs will be harder to find, if it's not under the carpet.
    Yes... The rod can be bent to compensate for thicker carpet and/or padding but I would look into adjustments at the engine end of the throttle cable before resorting to "tweaking" the arm.
  5. newtodu06
    21
    Jul 22, 2015
    Raleigh, NC
    Thanks guys.
    I just checked the floor pan and the holes are there for the floor mounted pedal. I’ll check out a gas pedal diagram and make a parts list. Tricky part is getting through the carpet. So....here goes...
  6. x77-69z28
    321
    27
    Feb 5, 2010
    I have the utmost confidence in you! I just did a quick eBay search and got an email from a member and 2nd gen judge at the Camaro nationals, Steve Nuwer. He has reproduced the parts for the floor mounted gas pedal. Check out www.2ndgenz.com
  7. l16pilot
    1,813
    130
    Dec 13, 2004
    Hurlock, MD, USA
    Not quite sure what you mean. the factory cut out a square-ish section of the carpet as the floor bracket mounts directly to the floor pan/toe-board. I can send you a .pdf instruction sheet on the installation if you wish, but I cannot upload a .pdf in this reply, so send me your email address through the "conversation" function.
  8. newtodu06
    21
    Jul 22, 2015
    Raleigh, NC
    Nice! Thanks!
  9. newtodu06
    21
    Jul 22, 2015
    Raleigh, NC
    If you would send me that, that would be great. I'll do that in a bit.
    Thanks.
  10. gpm6367
    880
    45
    Feb 12, 2005
    New Joisey
    Plus one...big time...
