New Urethane Nose Gaps at hood are off just a bit I need help
Discussion in 'Body Restoration' started by RickM, Nov 9, 2018.
  1. PHROG
    PHROG New Member
    Sep 27, 2017
    How about running a tape line carrying the hood peak onto the bumper cover and blocking the urethane peak to match? I believe that would change the visual to make the gap appear to lineup. Just my 2cents.
  2. cadillac_al
    cadillac_al Veteran Member
    832
    85
    Apr 22, 2015
    Maine
    I would think you could move the front of the fenders over; shift everything at the core support. Just my thoughts. I know fixing gaps will drive a guy crazy.
  3. 2000SS
    2000SS Member
    53
    Jul 9, 2009
    Ohio
    Where does one find this "assembly manual" you speak of?
  4. RickM
    RickM Veteran Member
    474
    43
    Apr 16, 2004
    Gaithersburg, MD
    Assembly manuals for our cars are readily available. Just go to ebay and do a search or look at any of the parts vendors like Classic Industries or NPD.
  5. Desert_Dick72SS
    Desert_Dick72SS Veteran Member
    197
    Feb 10, 2009
    San Francisco Bay Area
    After much swearing and adjusting, the gaps around my hood ('72 RS/SS) were still not close enough for my taste and I had no more room to adjust. Best solution in my case was to weld 1/8" steel strip to one side and one half of the nose of the aftermarket hood. Then we just sanded off what we needed to get the gaps even. Very little filler to chip or break off on edges...steel is best if welding is an option....really hard to see what was done after body and paint were finished.
    -Rich
