New way to change oil
Discussion in 'The BS Topic' started by RS1979, Apr 4, 2016.
  1. RS1979
    3,712
    707
    Jun 18, 2013
    Memphis, TN
    One of my wholesale accounts had a car come in for an oil change. The customer told them that when he had the oil changed in California they couldn't get the drain plug out of the oil pan. They drilled a hole beside the original drain plug to drain the oil and put a rubber plug in it to seal it up. Creative thinking is usually a good thing; but, I'm not so sure in this case.
  2. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
    Um...well...that is creative.
  3. 1BAD78
    1BAD78 Veteran Member Gold Member
    814
    Apr 12, 2007
    Broken Arrow Ok
    That is why I have always done my own oil changes.
  4. muscl car
    21,636
    611
    Jul 8, 2001
    High Desert of Hesperia Calif
    Wow !!!! :confused: :eek:
  5. BMR Suspension
    BMR Suspension Veteran Member
    245
    Jun 7, 2013
    Tampa FL
    I think I now have seen everything!
  6. Twisted_Metal
    26,949
    930
    They didn't try very hard to remove it.... It's not round! :screwup:
    Probably charged the customer $10 for the rubber plug too. :confused:
  7. muscl car
    21,636
    611
    Jul 8, 2001
    I think putting a hose down the oil dipstick tube into the sump and attached to a vacuum pump would have been easier !!
  8. slayer021175666
    slayer021175666 Veteran Member
    1,217
    60
    Feb 29, 2016
    Idaho
    Why not just chew up some bubble gum and stick it in there?!
  9. COPO
    17,685
    683
    Dumb ass. Put some muscle into the wrench or get someone else. Idiots.
  10. chevyJeff1
    chevyJeff1 Veteran Member
    730
    34
    Nov 2, 2002
    Shenandoah VA. Listening to the blues
    They couldn't remove a oil pan bolt?
    What a bunch of sissies
