Next issue!
Discussion in 'High Tech Retrofits' started by chiliz28, Jul 26, 2018.
  1. chiliz28
    chiliz28 New Member
    16
    Apr 19, 2003
    LA, CA
    Hi There:
    I have transplanted a 2001 5.3 vortec in my 79 Z28. My current problem is the engine keep cranking with no start when the ignition switch is turned on. I can start the engine with remote starter with the ignition switch in accessory, I hear the fuel pump comes on. Initially I had an issue that the ignition key wouldn't go further than the accessory but that solved. The issue was related to me removing the safety switch linkage and for some reason the connection on steering connection section was pushed down. Does my new issue can be related to the old one?!
    Thanks
    [​IMG] [​IMG]
  2. orkin
    orkin Veteran Member
    257
    Apr 27, 2011
    Texas
    It sounds like you wired the fuel pump, ignition, and/or computer into the accessory circuit. The accessory circuit turns off while you are cranking, but not the ignition circuit.
  3. mrfleet12
    mrfleet12 Veteran Member
    402
    134
    Aug 8, 2014
    West of Chicago IL
    This sounds accurate, you need power while the engine is cranking and obviously after it starts.. What control system are you running?
