Next step is interior
Discussion in 'Interior Restoration' started by 76z28, Dec 16, 2015.
  1. 76z28
    76z28 Veteran Member
    2,024
    47
    Jun 29, 2009
    bakersfield
    Well, I have decided to redo the interior of my car.. Finally
    Got a quote to recover the door panels, seats, and dash in vinyl(leather is WAY too expensive!). Looking at having them install carpet too. The interior is in pretty good shape, just need a little refresh so I might as well do it!
    Should I put padding(dynomat or something) under the carpet?
  2. 76z28
    2,024
    47
    Jun 29, 2009
    bakersfield
    Taking the car down saturday.
    Basically going to have the outer seat covered in something similar to this with the same carpet as in the picture:
    Inserts/dash covering:
  3. mjoc
    mjoc Veteran Member
    3,511
    Apr 29, 2003
    Sherman Oaks, Ca
    Yes you should put dynomat or something under the carpet as well as the package tray, the sail panels, the roof and the doors. If you can since I assume they are pulling dash to wrap it. put sound deadening against firewall as well.
    Michael
  4. 76z28
    2,024
    47
    Jun 29, 2009
    bakersfield
    I will be putting it on the front firewall and floor under the drive/passenger.
  5. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    matting
    If you don't want to spend a ton of money the CarInsulation product is good and very reasonably priced.
    Quick install to, if you're paying someone to do it.
  6. 7TZee
    7TZee Member
    60
    Oct 29, 2015
    Deep South
    Do you have this in your car? What difference can you tell compared to the factory sound deadening material? If any.
