No turn signals
Discussion in 'Electrical Systems' started by Fitza6, Oct 12, 2019.
  1. Fitza6
    Fitza6 New Member
    11
    Jun 8, 2016
    laurens SC
    Been running leds in all rear bulbs, turn brake and rev with no issues. installed leds in front grill turn signals and now no turn signals at all, no green light even comes on in the dash when arm is moved left or right. Changed turn signal flasher to led type still nothing. Fuse checks good. Looking for ideas. Im using the elec schematic from site. Key turned on. 1979 Camaro
  2. Zspoiler
    Zspoiler Veteran Member
    3,186
    247
    May 6, 2012
    Federal Way, Washington
    Check your wiring and make sure you are getting power to your switch .and check your switch as well.One step at a time.
  3. 77thor
    77thor Veteran Member Lifetime Gold Member
    2,528
    12
    Mar 22, 2002
    Milwaukee, WI USA
    Some of those LED electronic flasher modules are just crap.
    I would try another different brand.
  4. Gary S
    22,323
    727
    Since the problem started with the LED front lights, the problem is almost surely there. Make sure you have LEDs that can handle dual polarity. Most of the LEDs sold for in cars are poorly designed and thought out.
    I'm betting that if you put back in incandescent bulbs and flasher they will work. That tells you that the switches and wiring in the car is just fine and the problem is with the changes you did.
  5. Twisted_Metal
    26,899
    909
    ^+1
    What year Camaro?
    Not sure about all of them but the 78-81 front lights switch polarity through the signal circuit.
  6. Fitza6
    Fitza6 New Member
    11
    Jun 8, 2016
    laurens SC
    1979
  7. Fitza6
    Fitza6 New Member
    11
    Jun 8, 2016
    laurens SC
    Im not pulling the column apart until I have exhausted all other possibilities.
  8. Fitza6
    Fitza6 New Member
    11
    Jun 8, 2016
    laurens SC
    1979
  9. Fitza6
    Fitza6 New Member
    11
    Jun 8, 2016
    laurens SC
    I will go back to where I started with the old incandescent bulbs and see what takes place.
  10. Jim Streib
    346
    40
    Apr 6, 2004
    Saint Louis, MO USA
    And some require an adaptor to change the polarity of them depending on the vehicle and wiring design:
    Jim
