odd trans issue
Discussion in 'Transmission & Driveline Topics' started by cutty, Sep 5, 2016.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    just switched out my trans, for 1 thats been rebuilt, seems to work, but issue i got is if i put it in drive, its like in neutral,( which also works) 2nd seems to be my drive, while 1st is my 1st and 2nd gear, im hoping its just the valve body, anyone ever have this issue, think my buddy installed a trans go kit in it,
  2. grzewnicki
    3,447
    175
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Check the shift cable for adjustment. Might have to google your type trans to see how it is properly adjusted.
  3. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Always double check the indents are perfect when swapping trans.
    Good luck.
  4. cutty
    342
    Dec 12, 2008
    ontario canada
    sorry for the delay, been working tons, shifter cable is perfect. what would happen say wrong gaskets between plate? id like to have drive in drive and be able to use and have control of my first gear, ordered a new valve body. but puzzled at why
  5. grzewnicki
    3,447
    175
    Dec 9, 2009
    Yea Someone could have screwed up the valve body plate, drilled a hole in the wrong spot etc.
  6. cutty
    342
    Dec 12, 2008
    ontario canada
    So should be 1 of the 2? Valve body or separator plate. Was scared was inside trans. Fingers crossed it isn't.
  7. grzewnicki
    3,447
    175
    Dec 9, 2009
    Don't know what trans you have but for the TH350 valve bodies and plates are on ebay for reasonable price, I'd grab both and throw them in and see if it fixes your problem.
