Oops! My weld broke
Discussion in 'Transmission & Driveline Topics' started by czizza, Dec 19, 2015.
  1. big gear head
    big gear head Veteran Member
    6,177
    79
    Jul 30, 2001
    Central City, Ky.
    It looks better. I think you are having a hard time seeing the puddle. It might hold pretty well this time.
    Your weld lens may be dirty, or it may be too dark. You may need to use reading glasses or get a cheater lens. Anything you can do to see the weld better will make you a better welder.
  2. czizza
    czizza Veteran Member
    1,008
    52
    Jan 8, 2004
    N. Massapequa, NY, USA
    You are absolutely correct; when I weld it goes totally black and I can just see the glow I cannot see the line so I am welding by the force.
    Where can I get a new lens? Harbor Freight?
  3. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Are you using a auto helmet or old school. Looks better. Still less wire and you have got to see the puddle. I set my auto to 9 or 10 inside. Another trick get head/helmet as close the the welding as possible. Great improvement. On my old school helemet I use a number 10 lens.
  4. CasperCasper
    CasperCasper Veteran Member
    1,068
    174
    Aug 11, 2015
    Couple things, when you're welding get your eyes to the level of the stinger and watch the stinger come towards you. I never really realized how useful this is until I started using a TIG where you pretty much have to do this. Always push, never drag, this keeps the gas flowing on the molten metal which is very susceptible to oxidization (slag). With that thickness of steel you can grind a DEEP 45 into both sides and just hammer the weld into it. Crank your power way up, that thickness of steel isn't going to burn through easily. The weld metal you fill with is just as strong as the steel you're welding on, the weakness comes from the "heat affected zone," which is essentially where the grains of the metal are trashed from welding, so dont be afraid that grinding a vee will make things weak. I suspect your welder doesn't have enough power to penetrate deeply on that stuff, it looks like its sitting on top a bit still but may hold up just fine. If it breaks, it cost you virtually nothing so who cares ! One other note, the area where the two round pieces meet is seeing a really high stress due to the mechanical advantage from the shifter. If you can weld the full way around in that area you'll be much better off !
  5. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
    turn up the heat and let it eat ...
  6. big gear head
    6,177
    79
    Jul 30, 2001
    Central City, Ky.
    What lens are you using?
  7. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    Also it should sound like a sizzling egg on a hot griddle.
  8. czizza
    1,008
    52
    Jan 8, 2004
    I replaced my helmet and it sizzles now when I weld ... speed need to come down a bit ... you can see it works better in the 2nd weld.
    Thanks for all the help.
  9. perkalator
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Soo close. Great job sticking with it and learning how to do it yourself correctly. A little less wire speed,
  10. big gear head
    6,177
    79
    Jul 30, 2001
    Central City, Ky.
