Opening Nitrous Bottle with a Ball Valve. Need Advice.
Discussion in 'High Performance Modifications' started by slayer021175666, Feb 24, 2019.
  1. slayer021175666
    slayer021175666 Veteran Member
    1,217
    60
    Feb 29, 2016
    Idaho
    Hi Guys,
    I been looking at remote nitrous bottle openers. They are expensive and require wiring and switches to be installed. Couldn't a guy just put a ball valve somewhere on the nos line where he could reach it from the driver seat? Fast on. Fast off. Way less $$$ and way less time. Probably less likely to fail, as well.
    https://inductionsolutions.com/shop...tles-components/high-flow-quarter-turn-valve/
    Is there any folly in what I'm thinking of here?
    Thanks.
  2. 80sz
    80sz Veteran Member
    3,192
    420
    Feb 2, 2014
    Buffalo,n.y.
    What were ya watching fast and furious ??? Pop the trunk and turn it on
    budro6968 and Bandit723 like this.
  3. slayer021175666
    1,217
    60
    Feb 29, 2016
    Idaho
    Well, that was no help. Anyone else?
    80sz likes this.
  4. 80sz
    80sz Veteran Member
    3,192
    420
    Feb 2, 2014
    Buffalo,n.y.
    Looks like it would be quick and easy. Have to add getting hose spliced or buying a pre made section of hose to cost.
  5. slayer021175666
    1,217
    60
    Feb 29, 2016
    Idaho
    Ya. I was thinking about a new line or 2 for it. I'm just a nitrous noob and although it seems like it'd be fine to me, I thought I'd ask if anyone else knows of a problem in doing it this way.
  6. 1980RS
    1980RS Veteran Member
    3,400
    590
    Jun 17, 2006
    MN
    That would be nice on the street but I know it's not legal for the track.
  7. SRGN
    SRGN Veteran Member
    681
    238
    Feb 20, 2009
    Central NJ
    Remote bottle opener is $250, and can be wired up in under an hour. If that is too expensive and difficult, chances are you shouldn't be running nitrous, for the safety of yourself and others.
    BonzoHansen and muscl car like this.
  8. slayer021175666
    1,217
    60
    Feb 29, 2016
    Idaho
    Seems like the ball valve would be less dangerous and more fail proof than relying on wires, a switch and an electric motor.
  9. Rich Schmidt
    Rich Schmidt Veteran Member
    4,278
    38
    Mar 27, 2010
    Denville NJ
    You could always put the ball valve at the bottle and use a cable to operate it. A choke cable would work if the valve works smoothly enough.
  10. ssupercoolss
    ssupercoolss Veteran Member
    764
    191
    Nov 3, 2015
    PA
    I know nothing about nitrous. But, i was going to suggest a 12volt dc electric ball valve, but i see the bottle opener actually opens the bottle. If you were to use a motorized ball valve, (which most will close when power is removed), would still leave your bottle open.
