Operation LS7
Discussion in 'High Tech Retrofits' started by badazz81z28, Mar 5, 2017.
  1. badazz81z28
    17,401
    604
    Alabama
    ok, I got an LS7 and plan to do the whole head and cam swap deal. There are barely any threads that detail such a thing plus it gives me something to do. So here we go. It's gonna be slow because it's an expensive task..... I went ahead and stripped the engine down.
    QUAKE_WARS likes this.
  2. Bandit723
    Bandit723 Veteran Member
    3,150
    464
    Oct 1, 2016
    Waupaca WI
    Is this a used engine? LS7 505 HP crate engines goes for just short of 14 Grand new. How much HP are you looking to build out of this?
  3. badazz81z28
    17,401
    604
    Alabama
    This is a used pull out. I'm $7500 invested in this, but still a deal compared to a $13k new engine. Looking to get 550 rear HP. Stock is about 440-460hp. People are getting more but my goal is to still have it idle and drive with good street manners. Going too big on the cam is something a lot of guys do to get max hp.
    I'll put about $2,000 into it
  4. badazz81z28
    17,401
    604
    Alabama
    Going to try these bronze trunnion upgrades too over needle bearing
  5. Goat
    1,913
    44
    Jun 7, 2001
    moncure, NC
    What heads, intake you going with?
  6. badazz81z28
    17,401
    604
    Alabama
    I'm going with oem heads worked by Texas Speed and the stock intake
  7. badazz81z28
    17,401
    604
    Alabama
    Pulled the rockers, push rods and heads. All looks good so far. I kept everything in order even though I plan to replace the push rods. I loosened all the rocker while both valves were closed and loosened the head bolts criss cross outside in
  8. badazz81z28
    17,401
    604
    Alabama
    Next is cleaning the head bolt holes for studs
  9. Bandit723
    3,150
    464
    Oct 1, 2016
    Waupaca WI
    This looks like it is in good shape. How many miles are on the engine?
  10. badazz81z28
    17,401
    604
    Alabama
    About 30k
