Operation LS7
Discussion in 'High Tech Retrofits' started by badazz81z28, Mar 5, 2017.
  1. badazz81z28
    17,164
    563
    Las Vegas, NV
    Well drove the car, its been a while I updated the post. The engine is so much nicer then the LS1. It appears to run smoother and the power is incredible.
  2. Bandit723
    Bandit723 Veteran Member
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Bet it felt good to finally take this thing out for a ride.
  3. Goat
    1,911
    44
    Jun 7, 2001
    moncure, NC
    Are you going to get it dynoed?
  4. CaliCamaro75
    CaliCamaro75 Veteran Member
    436
    31
    Sep 6, 2015
    Winchester,CA
    Congrats on the install!!! So is it done for now or do you have a few other little things to finish up?
  5. badazz81z28
    17,164
    563
    Las Vegas, NV
    It's all done with the exception of a vent tube going from the oil tank to the breather. Chassis dyno coming soon, but probably not until summer.
  6. thepilot
    thepilot New Member
    Sep 15, 2019
    Hello,
    How do you rate the work at texas speed? I'm needing to rebuild my LS7 with only 14,600 due to a failure that american heritage performance caused. The work was done by them at 11,800. I don't want to repeat the same mistake.
  7. 76z28
    76z28 Veteran Member
    2,061
    53
    Jun 29, 2009
    bakersfield
    Out of curiosity what happened?
    If I ever get rid of my big block I want to get an ls7... Too bad I'll never afford it
  8. thepilot
    thepilot New Member
    Sep 15, 2019
    Valve dropped. pieces out the exhaust. I have to either look for a reputable shop or start doing the tear down myself
  9. lightly-modded
    lightly-modded Member
    61
    33
    Oct 3, 2018
    New Hampshire
    Did they forget the valve lash caps with the titanium valves? It's amazing how quickly they will wear down if you do. If so I'm surprised you lasted almost 3k miles.
  10. thepilot
    thepilot New Member
    Sep 15, 2019
    most all of the miles were long distance driving. maybe that's why it went as long as it did.
