P0010 code
Discussion in 'High Tech Retrofits' started by ErikNORCAL, Jan 13, 2020.
  1. Knuckle Dragger
    14,952
    1,419
    Nov 2, 2002
    Waddell AZ
    No, sounds like you're set up like me. Yeah the GEN IV uses a amp probe and the BCM (indirectly through the ECM) controls the charge rate. Without the BCM it charges at a default rate I can't remember exactly what it was. It wasn't enough for my truck. I ended swapping the regulator on the Ad 244 160 amp Tahoe alt and using a smaller pulley. Mine is in a 1994 C1500 so clearance wasn't a restriction.
    A mail tune gets you running, dyno tune gets you close but data logging and tinkering gets you spot on.
