Paint advise
Discussion in 'Body Restoration' started by twestrup, Sep 12, 2019.
  1. twestrup
    twestrup Veteran Member Lifetime Gold Member
    139
    46
    Aug 22, 2018
    Hollister, Cal
    Getting ready for paint and trying to plan it all out. After we jamb the doors, fenders and hood, Should I put it all together and then paint it? I'm not real sure I can get assemble without a few nicks and dings. Getting the AMD inner fenders in place has not been easy, can't imagine doing it after it has been painted. Anyone know what the steps were back when it came down the assembly line.
    Zstar and hubedobeedo like this.
  2. GoldenOne7710
    4,825
    419
    Jun 23, 2004
    Athens, GA
    You'll be happier overall if you paint it in sections in my opinion. That's the way we did mine. The coverage in the door jams and back sides of the doors, under the deck lid/area, bottom side of the hood, cowl and engine bay were all easier to paint with it apart.
    hubedobeedo likes this.
  3. Twisted_Metal
    27,072
    1,004
    ^Those are the areas to jamb prior to assembly.
    Also, the entire perimeter of the door frame.
    What kind of paint?
    Metallic and pearls tend to lay out more evenly if the car is assembled prior to painting. (So adjacent panels are shot from the same direction.)
    I've seen cars where the doors were shot while on sawhorses (horizontal) and the color difference was obvious when they were bolted to the car next to quarter panels and fenders panels which were vertical when sprayed.
    It may have been due to the distance or angle of the paint gun but those little differences can effect the final product.
  4. twestrup
    139
    46
    Aug 22, 2018
    Hollister, Cal
    PPG, Cortez Silver, base coat, clear coat.
    Zstar likes this.
  5. Canadian Barton
    Canadian Barton Veteran Member
    242
    61
    Jul 20, 2015
    Alberta
    X2
  6. brooksman9
    brooksman9 Veteran Member
    6,108
    192
    Jun 10, 2007
    Olive Branch, MS
    First one I did I took the cap off, jammed everything, put it back together and painted the whole car. Single stage. Probably do something similar this time but I may put a coat in them reassemble and paint second coats.
  7. hubedobeedo
    hubedobeedo 3rd times a charm
    491
    157
    Jul 18, 2013
    Huntertown,IN
    have you had all the sheet metal installed and lined up to see if its good? you could paint the car in pieces all at once,or do what Twisted said. is it basecoat/ clearcoat or single stage lacquer or urethane.as stated earlier spraying metallic you would want to be careful how you set up job. i did my in stages and will sand all down for graphics and re-clear whole car. and yes my pearl matches adjacent panels(been in business for 40 years) painting has variables that you want keep at minimum increasing positive results .
  8. xten
    xten Veteran Member
    2,949
    1,720
    Sep 24, 2014
    Pittsburgh, Pa.
    If you are not experienced at this, put it together and paint it all at once. Pearl is more forgiving than metallic. There is no pearl in Cortez silver. It's all metallic, which is an aluminum flake that can be hard to get even. If you're worried about a paint line in the jambs, get them covered with base, remove the striker after you get the doors aligned, mask the hinge pillar. When you're done with your last coat of clear on the exterior, open doors and put a coat of clear on the jambs.
  9. Zoomin
    Zoomin Veteran Member
    102
    24
    Aug 5, 1999
    Oklahoma City, OK USA
    It's hard to think of a harder color to paint than Cortez Silver. If you paint it apart the panels are never going to match.
  10. twestrup
    139
    46
    Aug 22, 2018
    Hollister, Cal
    Thanks, I have been told that
