Painting an Aluminum Radiator
Discussion in 'Engine Topic' started by Green hornet, Oct 19, 2018.
  1. Green hornet
    Green hornet Veteran Member
    1,709
    283
    Oct 11, 2015
    North Bay, CA
    I purchased an aluminum radiator that has factory looking tanks. I want to paint the tanks, not the core so that it retains the stock look. Any issues with this idea. Any suggestions on type of paint / primer. I would prefer a rattle can product because of simplicity.
  2. gammamaniac
    gammamaniac Member
    62
    Feb 1, 2013
    Kansas
  3. 70-camaro
    70-camaro Veteran Member
    2,400
    444
    Mar 25, 2010
    marietta ohio
  4. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    for aluminum you should use an etching primer followed by the paint. do not use epoxy over the etch primer, it will peel off in short order. Bulldog is for plastic bumpers BTW.
  5. 70lt1z28
    3,430
    682
    Oct 3, 1999
    Beavercreek, Ohio, USA
  6. Green hornet
    1,709
    283
    Oct 11, 2015
    North Bay, CA
    I ended up using engine paint from Duplicolor. No primer needed. I scuffed it a little and cleaned it with lacquer thinner. Coated it with low gloss black. It turned out nice and is holding up well.
    dale68z and 70-camaro like this.
  7. CAMeeks
    CAMeeks Veteran Member
    694
    37
    Jan 5, 2014
    Deer Park, TX
    Bulldog® Adhesion Promoter is designed to promote paint adhesion to all automotive surfaces, even problem plastics. It works equally well on all flexible or rigid plastics, fiberglass, aluminum, glass, chrome, vinyl, galvanized metal, and painted surfaces. Bulldog acts as a tie coat by allowing several different surfaces to be painted at the same time to assure a smooth, flawless, durable finish every time.
    Seems to cover more then plastic.
    70-camaro likes this.
  8. Jeep43
    Jeep43 Veteran Member
    1,305
    48
    Mar 30, 1999
    Connecticut
    I would try to use as little paint as possible as to not insulate the fins from the air.
  9. 70-camaro
    2,400
    444
    Mar 25, 2010
    marietta ohio
    I used taps and paper and didn’t paint my fins.
  10. 70lt1z28
    3,430
    682
    Oct 3, 1999
    This actually gets very technical while as you say the paint can act as an insulator (impedes heat transfer) , but black also enhances emissivity:
    Emissivity is a measure of the efficiency in which a surface emits thermal energy.
    https://en.wikipedia.org/wiki/Emissivity
    https://www.thermoworks.com/emissivity_table
    Generally, a thin coating of black on a radiator enhances its ability to move thermal energy from the inside to the ambient air. They didn't paint the radiators from the factory black without good reason.
