Painting plastic panels
Discussion in 'Interior Restoration' started by 1981zapper, Aug 12, 2018.
  1. 1981zapper
    1981zapper Veteran Member
    1,317
    Apr 28, 2009
    Southern Ontario, Canada
    I purchased some OER replacement interior panels, along with Sem interior paint system (Soap, plastic prep, Adhesion promoter, Color coat & satin clear), I followed the instruction to the T and hung my panels.
    I'm finishing up my last panel and putting the final coat of clear on, as I walk away my panel falls on the painted surface:mad::whine:
    looks a lot worse in person, how can I fix this? I'm very upset
  2. DrPepper
    DrPepper Veteran Member
    141
    26
    Aug 29, 2017
    Central VA
    If it were mine, I'd apply some adhesion promoter and repaint w/ the color. Blend the new color into an area about 8" bigger than the original scratched area. I've done this before w/ success.
    Good Luck
  3. 80 Z28
    80 Z28 Veteran Member
    1,205
    Mar 25, 2000
    Regina, Saskatchewan, Canada
    No to hijack your thread, but is that a camel tan interior? Would you happen to have the SEM number for that colour?
  4. earnhardtgm3
    earnhardtgm3 Veteran Member
    2,494
    33
    Dec 18, 2007
    Camaro Country,GA
    Ditto as DrPepper stated.....:)
  5. budro6968
    budro6968 Veteran Member
    2,779
    389
    Apr 2, 2016
    Jax Florida
    Scotch brite the small spot Light scuff the rest and re apply.
  6. ZEN357
    ZEN357 Veteran Member
    257
    52
    Feb 12, 2018
    Scuff, reapply paint and blend. That's what I did when I dropped a freshly painted panel. It really sucks when that happens.
  7. 1981zapper
    1,317
    Apr 28, 2009
    I'm using SEM Camel #15173
  8. 80 Z28
    1,205
    Mar 25, 2000
    Thanks
