Parking Brake Not Engaging?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by sandiego74, Jun 6, 2018.
  1. CorkyE
    10,262
    428
    Not being snarky, I don't really know your system. Is the adjustment made on the cable or at the caliper?
  2. cadillac_al
    cadillac_al Veteran Member
    830
    85
    Apr 22, 2015
    Maine
    I think Skip Fix has accepted reality. Rear disc park brakes work marginally and barely pass inspection. I have an Acura with rear discs that barely holds the car too. It's not just GM's brakes.
    sandiego74 likes this.
  3. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,119
    61
    Feb 23, 2009
    San Diego, CA
    The adjustments are made by tightening the bolts that tie the rear cables to the front pedal cable. I don’t think the calipers have any adjustment to them.
  4. flht99b
    flht99b Veteran Member
    205
    37
    Nov 28, 2014
    Knoxville, TN
    My son has a 2007 Solstice GXP. About once a year his E brake no longer holds the car, disc's in the rear, hand brake lever between seats, cables from hand brake to rear calipers. There are many "remedies" for this but the one that works and I use is, remove rear calipers, with a tool wind the pistons back into the calipers till bottomed, re-install the calipers and then pump the brakes pedal 4 or 5 times till pedal is at normal height and hard. After all this E brake works as designed. If the calipers used in these rear disc brake kits are the GM type that to push the pistons into the calipers you must wind it in, you may have to try the procedure I've outlined above. Adjusting the cables won't work and my cause the pads to drag the rotor.
  5. badazz81z28
    16,567
    430
    Las Vegas, NV
    What does the lever on the caliper look like? It it fully actuating? A mechanical parking brake not holding is adjustment. BTW, it’s not uncommon for the adjusting nut on the stud to vibrate loose and loosen up the adjustment.
  6. 8pack
    2,617
    148
    Aug 29, 2007
    Western, MA
    Don't try any further adjustments, in fact you may have your cables too tight already but see how this works:
    With the '79 Trans Am brakes, which I think are pretty close to the same as you have, which I think use the cadillac calipers (TA calipers are a little different) try pushing and releasing the brake fully 30 times, yes 30 and fully depress it. That should restore it if they are ratcheting adjusters. That basically "ratchets" the bad closer to the disc. As the pads wear they get farther away and if you don't regularly use the parking brake they get out of adjustment.
    I tried adjusting everything and couldn't get them to work. I did the above after reading up on a TA site and it went from rolling on a small incline to holding on really steep inclines like my Kwik lift ramps.......
  7. badazz81z28
    16,567
    430
    Las Vegas, NV
    ^^ What if you push and hold the brake while actuating the parking brake?
    cadillac_al and sandiego74 like this.
  8. sandiego74
    1,119
    61
    Feb 23, 2009
    San Diego, CA
    This thought never crossed my mind, and it makes complete sense. I'll definitely try this and depressing the brake pedal while adjusting the parking brake cables. Thank you, everyone! This is why I love this forum.
  9. 8pack
    2,617
    148
    Aug 29, 2007
    Western, MA
    I would try it first without holding down the brake pedal. It may not ratchet in with the pads all the way against the rotors. Look forward to hearing the results.
  10. roadrace2
    roadrace2 Veteran Member
    1,665
    38
    Jan 13, 2000
    Earth......?
    food for thought......I had similar issues - rear discs not locking up properly with emergency brake engaged.....anyway, the drivers side cable was rubbing against the frame rail - the protective coating partially "melted" into the steel core cable portion - thus seizing the cable - cable was not able to properly engage the parking brake mechanism = took the cable out, removed the outer coating that was melted, re-installed cable - now parking brake works perfect.
