Parking brake
Discussion in 'Tips 'n' Tricks Topic' started by Jak33C, Jul 20, 2016.
  1. Jak33C
    Jak33C New Member
    8
    Jul 13, 2016
    Lexington, KY
    In my 1981 camaro I have disconnected the two bolts through the firewall and the one through the kick panel but it won't come off. Is it glued on? What am I doing wrong? I need to get the drivers side kick panel off.
  2. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    Is the tar-like, sound deadening material causing it to stick?
    http://www.nastyz28.com/forum/showthread.php?t=21826
    Also, according to a post in that thread (#9), there's a bolt at the top of the assembly, not just through the kick panel.
    You can see the upper, slotted bolt hole in this photo:
  3. Revin
    Revin Veteran Member
    269
    22
    Aug 31, 2016
    Round Rock , TEXAS
    yep just took mine out yesterday.
    upper and lower bolt and 3 nuts. ( 2 on inside firewall and one on a stand off in side.
    Yep the sound deadening junk was melted on mine and had to wiggle it off.
