Hello, Just picked up a 74 camaro, has z28 badging, not sure how to tell if it's a true z28 or not. Has power windows if anyone is looking. Has a posi 10 bolt rear, havent determined the ratio yet. Dash is in decent shape, has a 7000 tach cluster. Lots of good parts on it, if you dont see it listed here please ask. Rear spoiler: $100 17 inch American racing wheels, have 2, believe they are torq thrust: $80 each Front subframe: $350 Front and rear bumpers: $200 each Headlight extensions: $50 each Header panel: $100 Tach cluster: $350 Located in Arizona and can ship
If it has a "T" in the VIN, it's a Z28. You may want to post a pic of the VIN. If the motor is around, does it have an EGR valve? Valve cover wire loom clips? Does it have the exhaust heat shields?
Does the top and lower grille have any cracks on them? Also, does it have the following parts? 1. Under dash courtesy lights setup with the wiring harness. 2. Seat belt Interlock switch/bracket that attaches on top of the driver side wheel well. I may be interested in these parts if they are available and no cracks in the grilles. Please post photos of the engine bay area. Thanks
The motor isn't around. Dont think the exhaust heat shield is there anymore. Attached the vin, 1S87T4N172453 is what it looks like to me
The plastic grill pieces dont have any cracks. $75 for the both of them. I dont see a factory under dash light setup here. Attached a picture of driver wheel well, let me know if what you are looking for is there. Also attached engine compartment. Engine was pulled before I got it.
Ya someone put work into it at some point. swapped the roof and a rear quarter panel, was blasted and left in the rain. Guy I got it from said he bought it with 2 other camaros from a body shop that went out of business
Looks like you have the RH side. The LH side does not come up the firewall so I can't see it in the engine bay pic.
