pcv/breather setup
Discussion in 'Engine Topic' started by 408maro, Mar 5, 2015.
  1. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    Curious how you'll are running your pcv setup. Or just using 2 breathers?
    My sbc has a breather on one valve cover and just a pcv not going anywhere because I have nowhere to route it to. The only port on the carb goes to the brake booster
    Smokes like crazy through the breather and after some hard driving starts to leak.
    should I get a catch can? I just want it be right. Thanks
  2. kain13
    kain13 Veteran Member
    519
    Jul 6, 2006
    Lubbock,Texas
    take that plug out of the intake and put it there
  3. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    The one on back of intake? I think I'd have to add another carb adapter to fit? How about the carb? Which port would I hook it up to The top or bottom? Or would it not work that way?
    Thanks
  4. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    15
    Sep 16, 2012
    NorCal
    I run an air/oil separator in my PCV line. Made a huge difference in exhaust smell and under hood cleanliness.
    http://www.nastyz28.com/forum/showthread.php?t=287104
    I have it plumbed into the nipple under the secondary bowl, and my brake booster draws from the port on the intake for cylinder #8. I run a 1" carb spacer so a 90° elbow does the trick
    tim
  5. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Hmm any pics of the setup with air cleaner off? Seems to have worked for you. Have a breather on the other side? Also a link for the part?
    Thanks
  6. lumpy12
    727
    15
    Sep 16, 2012
    NorCal
    I used this one from Moroso and I'm quite happy with it.
    http://www.summitracing.com/parts/mor-85601
    Don't have any pics at the moment of the back side of the carb - sorry, but I ran the elbow in where the pipe plug is under your rear accelerator pump.
    Yes, I'm running a breather on the other side valve cover.
    Tim
  7. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    You use the 90* edelbrock elbow right here?
    Looking at the pic don't think I'll need another carb adapter?
    You don't get no oil coming out of vent or smoke from breather?
  8. Lowend
    15,009
    480
    Mar 25, 1999
    San Jose, CA, USA
    Air Oil Separator with a PCV is a good way to go.
    A straight breather just doesn't provide enough evac. The AOS will keep oil out of the intake tract, which is a good thing on many levels.
    I like that Moroso piece
  9. gramps
    gramps Veteran Member
    983
    345
    Jul 5, 2009
    mankato, mn
    Take the plug out of the back of the intake, install a nipple that's on a 90* Or a "street elbow" brass fitting and a regular nipple on that. Should not have to use another carb spacer.
  10. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
