Peanut Port BB testing
Discussion in 'High Performance Modifications' started by 1980RS, Sep 8, 2018.
  1. 1980RS
    1980RS Veteran Member
    3,701
    706
    Jun 17, 2006
    MN
    So, I got to go out and test some more Carbs but not much else as the track was packed this test day. Here is what happened.
    The start of the day I used the 650 Speed Demon and it ran 12.22@107
    2nd test was my 850 Might Demon A/D carb and it ran 11.92@110
    3rd test was interesting, I decided to just flash the converter instead of loading it like I always do and it paid off. Even hesitating a touch the car ran 11.83@112 with 1.62 60ft.
    4th run I changed squirters to 35 and 40 the car ran another 11.83@111.6 buy the 60's were now 1.57
    5th run I tried the Predator carb, with not time to play with it the box ran 12.02@110 better mph than I expected but a poorer ET.
    6th and final run I put a box stock Mighty Demon 1000 (basically an 850 with down leg boosters. It ran 11.84@111.65 with a 1.59 60 ft.
    The 1000 Demon surprised me as I though the thing would fall on it's face with the non A/D boosters.
    I did figure out that by the 1/8 mile times I need to put a single plane intake on the car. It ran 7.44 and that equals to a 11.60 time so we figured out that it slow on the top end, which happens sometime with a dual plane intake. Next race I will put in an 8" converter with a new intake to see what happens. All in All a good day with the little tiny ports.
    jeff swisher and PalmbchZ28 like this.
  2. 77 cruiser
    77 cruiser Veteran Member
    547
    25
    Nov 17, 2006
    Frostbite Falls MN
    What track were you at?
  3. 1980RS
    3,701
    706
    Jun 17, 2006
    MN
    Rock Falls Wi.
    Z28-79 likes this.
  4. Chevyforever
    Chevyforever Veteran Member
    729
    99
    Jan 4, 2011
    When you say peanut port which casting # are you working with and how many cubic inches ?
  5. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    Central New Yorkistan
    I haven't raced since the mid 90's so components could be better nowadays. However, if I loaded the convertor I wouldn't get near as much stall as I did when I let the car idle and cracked the throttle on the last yellow.
    NYH1.
  6. 450bench
    450bench Veteran Member
    3,192
    78
    Feb 25, 2002
    memphis, tn-shelby
    I took a ride in my buddy's 69 camaro with a ht502 crate motor. Just a 502 with peanut ports and a tiny hr cam. He got the engine off craigslist for $2000. He put the zz502 hydraulic roller in it and didn't change anything else other than the zz502 valve springs. I give him a 163 square port intake that we put on it using square port gaskets and an 800 dp.
    Freaking thing was an absolute animal. Seriously would pull your face off.
    I think it runs mid 11s shifting at like 5200 rpm.
    jeff swisher likes this.
  7. 1980RS
    3,701
    706
    Jun 17, 2006
    MN
    236 casting, 461 ci.in. 7.9 compression
  8. Z28-79
    Z28-79 Veteran Member
    103
    Mar 22, 2016
    EAU CLAIRE WI
    I was there spectating yesterday, what does you car look like?
  9. 1980RS
    3,701
    706
    Jun 17, 2006
    MN
    So I can be clear on this, you put the big port intake on the little heads?, Humm, may have to try that. I have done it on 781's but not on a Peanut Port. I did watch my gopro videos today, the car does flash to 4500 so I am not going to change the converter at this point. I think this is plenty, so I might either try that 163 intake swap or use my ported single plane. I do know the 163 intake has a huge plenum as does my sq. port Weiand Team G dual plane but that has the divider cut out.
  10. 1980RS
    3,701
    706
    Jun 17, 2006
    MN
    1980 Red and Black Rally Sport with the air cleaner sticking out of the hood.
