Perfect straight taps every time
Discussion in 'Tips 'n' Tricks Topic' started by camaro71/holland, Jan 8, 2017.
  1. camaro71/holland
    890
    20
    Aug 27, 2003
    The Netherlands
    This simple DIY tool will save you some stress next time....
  2. 70-camaro
    70-camaro Veteran Member
    1,009
    102
    Mar 25, 2010
    marietta ohio
    As a machinist I have 4 sizes of tap wrenches at home and work. The T handle tap wrenches are as handy as the one posted.
  3. mlburk
    mlburk Veteran Member
    117
    Feb 26, 2008
    ohio
    I think he is referring to the nut and washer set up .
  4. camaro71/holland
    890
    20
    Aug 27, 2003
    The Netherlands
  5. CasperCasper
    CasperCasper Veteran Member
    955
    90
    Aug 11, 2015
    I quite like this idea, nice job. When tapping holes on flat items I always start the tap in the drill press by spinning the drill press chuck by hand. I do a few turns of the chuck and then use my T handle tool.
  6. 71 rs BBC
    71 rs BBC Veteran Member
    471
    65
    Nov 28, 2016
    Indy
    I know this is old but for hand drilling and tapping I made a set of blocks one for each size with a tap drill and tap hole in each block. I also made a spring loaded pin out of drill rod that goes into the center on the back of the tap or tap handle on the Bridgeport or drill press for small taps. 10-32 / 24 and up get power tapped on the mill. I also burned out a lot of taps with the EDM. Lol
