Performer Intake and stock Air induction 80/81Z
Discussion in 'Engine Topic' started by manicmechanic, May 29, 2005.
  1. manicmechanic
    manicmechanic Veteran Member Lifetime Gold Member
    2,117
    Oct 24, 2000
    Tulsa, Oklahoma
    Who is running a performer fo similar manifold with the 80/81Z air induction air cleaner and hood? What mods are required to do so?
    78Z/28 done up like 81 383,350T...
    80Z/28 in restification 355,350T vortecs....
    1971 Firebird in waiting
    2002 T/A WS6 A4
    www.geocities.com/z28f41/ AOL IM Secondgenmanic
  2. Todd80Z28
    11,462
    212
    Jun 11, 2002
    Northern VA
    I run the Performer with the air induction. It works. I'm using a different seal, though- the wheel well rubber for a C4 Vette. It's more pliable than the factory air induction seal.
    Check my webpage.
  3. manicmechanic
    2,117
    Oct 24, 2000
    Tulsa, Oklahoma
    I also notice that's a Mustang base, will the factory base and lid work?
    2002 T/A WS6 A4
  4. zbugger
    zbugger Veteran Member
    3,773
    Aug 25, 2002
    My own personal hell...
    I've run one on my '77 Camaro with no problems. It fits just fine.
    [This message has been edited by zbugger (edited May 30, 2005).]
  5. Todd80Z28
    11,462
    212
    Jun 11, 2002
    Northern VA
    What???
    That's a 3rd Gen L69 (5.0l HO) air cleaner base. It has the same exact vertical dimension as the factory 1980 air cleaner. I have interchanged them a few times without issue.
  6. manicmechanic
    2,117
    Oct 24, 2000
    Tulsa, Oklahoma
    Whoa! My bad it's just when I see 5.0 HO I think late 80's mustang!
    2002 T/A WS6 A4
  7. Mitch'80Z
    Mitch'80Z Veteran Member
    1,336
    Sep 20, 2001
    Northeast Ohio
    Todd, I bought the whole 5.0/HO assembly (base, lid, hoses, and snorkels) only to find that it won't work with my long AC pump. The options are to either change over my whole Ac system or "manufacture" a new one using an old single-snorkle base and a cutting wheel.
    I believe that the air-cleaner base assemblies for the air-induction hoods were basically the same as the non-air inductions pieces. The differnce was the filter size and lid diameter.
    Any help?
    355 cid; World S/R Torquer heads; 9.3:1 Flattop hyper's; Comp XE262H; Weiand A+ intake; SMI custom Q-Jet; B.W. ST-10 4sp; Centerforce D/F clutch; Hurst Comp. Plus shifter; 3.08 posi; Flowmaster American Thunder exhaust w/ Jet Hot coated Hooker Comp's.
  8. Mitch'80Z
    1,336
    Sep 20, 2001
    Northeast Ohio
    Todd,
    I just got the inner fender seal from the Vette to use on my air-induction air cleaner. That is a PERFECT seal for the job. It's a bit thinner than the original so you can pick up a little clearance. It's also much more pliable than my 25 yr old cracked rubber seal.
    The original seal had flattened out so much that it was blocking a substantial amount of airflow. The new "Vette" seal is much better. All I had to do is cut off a few inches and glue it together with 3M weatherstripping glue.
    For those who are interested, the GM part number is #14104943. It is about $20.
    Thanks Todd.
  9. badazz81z28
    16,397
    407
    Las Vegas, NV
    I had a performer with a demon carb with a 3 1/2 filter on my 81Z. I had to cut the metal under the hood to close it. so if you run a shoter cleaner it should be ok
