Pic of parking cable?
Discussion in 'Body Restoration' started by badazz81z28, Oct 19, 2019.
  1. badazz81z28
    16,946
    506
    Las Vegas, NV
    Anyone have a picture of the outboard frame rail where the cable exits to the go to the wheel drum?
    Thanks
  2. badazz81z28
    16,946
    506
    Las Vegas, NV
    Nobody has a frame rail lying around?
  3. Gary S
    22,587
    808
    I don't have a picture, but there are good drawings in your Assembly Manual of the parking brake layout. I don't have an Assembly Manual for the later cars, and the cable setup for my 70 is completely different so it won't help you. An '81 Assembly Manual should have what you need.
  4. badazz81z28
    16,946
    506
    Las Vegas, NV
    I’m looking for a more precise location of where the hole is. I have the assembly manual and the Haynes and drawings don’t help.
  5. CDesperado
    3,590
    79
    Oct 1, 2004
    Dallas Texas
    As luck would have it, I happen to have exactly what you are looking for. I was just dealing with this yesterday.
    Here is a shot from the inside, including the screw that attaches to the interior of the floorpan. (This is the factory install on a 78 - I think the 81 is the same.)
    Here is a picture from the underside, with new cable.
  6. badazz81z28
    16,946
    506
    Las Vegas, NV
    You don’t happen to have a pic of the rear frame rail exit point?
  7. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    This what you are looking for?
  8. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    The front edge of the exit shield bracket is positioned even with the rear edge of the leaf spring bracket. I couldn’t get a picture to show that due to things being in the way.
