Pic Request: Emer. Brake pedal return spring
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 7dcamaro, Nov 23, 2018.
  1. 7dcamaro
    7dcamaro Veteran Member
    351
    Apr 10, 2012
    Warner Robins, GA
    Does anyone have an emergency brake pedal assembly off the car to be able to take a pic of the pedal return spring? I need to see where it attaches on each end. This on a 70 RS.
    Is this spring available any where?
  2. camaro71/holland
    1,217
    76
    Aug 27, 2003
    The Netherlands
    Best I've got:
  3. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,483
    143
    Oct 7, 2004
    Dickson TN.
    that's not the emergency brake.
  4. 70lt1z28
    3,311
    649
    Oct 3, 1999
    Beavercreek, Ohio, USA
  5. 79T/Aman
    2,483
    143
    Oct 7, 2004
    Dickson TN.
    this is on an 80, not sure a 70 would be the same, there are many things unique to the 70 but hope this helps.
  6. 79T/Aman
    2,483
    143
    Oct 7, 2004
    Dickson TN.
    be aware that the return mostly comes from the pressure of the e-brake springs inside the drum mechanism.
  7. COPO
    17,682
    683
    There's no spring. Here's a pic of a 1976.
  8. badazz81z28
    16,580
    434
    Las Vegas, NV
    Was gonna say...my 70 doesn’t have a spring on the pedal. The return pressure comes from the brakes themselves. I also don’t recall seeing a spring on the brake pedal either.
    Btw...the 70 Ebrake pedal assembly is unique. It also used a different park alarm switch.
  9. 70Chev
    70Chev Veteran Member
    244
    45
    Oct 21, 2012
    Brisbane, Australia
    Thee is a spring that holds the ratchet lever in place against the teeth of the ratchet mechanism. My spring broke but as others have said the pressure from the e brake cable enables the ebrake to return when released. The only issue I have had is when the ratchet lever turns all the way over because it doesn’t have a spring to keep it against the ratchet teeth so it doesn’t lock when you depress the pedal. I simply reach down and relocate the lever back against the teeth and all good. Hope this helps
  10. Scott51
    Scott51 Veteran Member
    622
    69
    Jan 2, 2012
    New Zealand
