picking up a junker
Discussion in 'The BS Topic' started by crsaz, Sep 22, 2008.
  1. crsaz
    crsaz Member
    88
    Jul 30, 2008
    phoenix,AZ
    Ok so Im suposed to be picking up a junker 3/4 ton 80' suburban with a running 454 and 400 tranny
    my question is what sould I expect to get at a scrap yard for it minus engine,tranny,hood, front fenders and rear dif.
    I was thinking I could sell the rear diff. and maybe the front on c-list for $50 a peice (dana 44 front) 14 bolt rear 4.10 gears. what should I expect to get for the emty shell
  2. RacingRob
    RacingRob Veteran Member
    413
    Aug 14, 2001
    Yorktown Heights, NY
    Somewhere online is the daily price of scrap metal by weight.
    Try googling it.
    I'd guess $100 or so for a shell. Just a wild guess though.
    RR
  3. gordonquixote
    3,016
    Jul 18, 2006
    Tallahassee, FL
    I think Mikey took one for a final lap recently.
  4. rscamaro73
    rscamaro73 Administrator Staff Member
    14,963
    9
    May 30, 1999
    Striking fear and destroying the enemy
    $2-300 or so....maybe more.....
    Around here, last time I was out, light iron was at $7.50/100lbs...that was on 7/23
  5. 79camaro2001
    4,767
    May 4, 2003
    Monroeville, PA
    To bad you are not closer or I would take your axles off your hand. They can probable be sold for more the $50 a piece. I would shot for $250- $300
  6. K5JMP
    10,216
    8
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    running about $10/100lbs... max about 400 if you leave the diffs on it
    and take only the motor and trans
    part it on CL and drag whatever is left across
  7. crsaz
    crsaz Member
    88
    Jul 30, 2008
    phoenix,AZ
    I'll see what I can get for the parts on c-list. differentials,tires+rims and scrap the rest because I can only have the truck at my house for a day or two so I will probably pick the truck gut it for the pats I need/can sell and haul it off to the scrap yard along with any other scrap I can find lying around to increase the weight. damn thats gonna be on hell of tiring day,gonna be damn hard to get a truck on/off a trailer if it has no wheels:screwup:
  8. Jim Mac
    Jim Mac Veteran Member
    2,196
    Dec 28, 2004
    tucson az USA
    before you pull the axles, I would do a search on craigslist and see if there are any other axles for sale. maybe get ahold of the sellers and see if they are getting any responses. Around here you see truck axles show up over and over. It may not be worth the hassle of pulling the axles. I would grab the motor, tranny, front clip pops off real easy. column might be worth selling. Just remember to pull the gas tank, battery, and on the tires. just load it up with the wheels on, with 1 lugnut on each wheel. when you get to the metal scrap yard, (not a junkyard) just pull the lug nut when you get out to show your ID. they just pick the carcass off the trailer, and the wheels just fall off. Good luck. jim
  9. crsaz
    crsaz Member
    88
    Jul 30, 2008
    phoenix,AZ
    I've seen a bunch of them up on craigslist but not many are there for very long(a week or two max)
    and my goal is to make $200, more would=profit $200=free engine/tranny
  10. Jim Mac
    2,196
    Dec 28, 2004
    tucson az USA
    You'll get more than that for just the scrap metal. a rolling shell should net you over 300 bucks. Jim
