pictures asked rear quarter replacement by rocker.
Discussion in 'Body Restoration' started by dutch73camaro, Nov 5, 2017.
  1. dutch73camaro
    dutch73camaro Veteran Member
    162
    34
    Jan 7, 2016
    Beverwijk, Netherlands
    hi guys looking for pictures of how the full rear quarter is welded originally by the rocker.
    there is an 90degree bend for welding on the AMD rear quarters but i can't place them.
  2. CamarosRus
    CamarosRus Veteran Member
    8,480
    139
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
  3. dutch73camaro
    162
    34
    Jan 7, 2016
    it isnt working ?
  4. CamarosRus
    8,480
    139
    Feb 16, 2000
    Old Link.......agreed no good....!
  5. lapedr
    lapedr Veteran Member Gold Member
    569
    17
    Jan 28, 2003
    Pembroke, GA
    Where is the outer wheelhouse?
  6. ronzz572
    1,990
    78
    Feb 8, 2007
    imperial pa
    I don't have a picture. But I can explain, There is a tab on the new quarter panel, It gets tack welded or spot welded on top the rocker through the door jam vent hole. Very difficult to get too.
    76 camaro car 1 likes this.
  7. lapedr
    569
    17
    Jan 28, 2003
    Pembroke, GA
    Also I see that there is an area of the rocker that appears to have been removed or cut off, there should be a additional bend of metal at the end of the rocker that goes upward, this is where the outer wheel house and the quarter would attach to
  8. dutch73camaro
    162
    34
    Jan 7, 2016
    thanks good photo !
