Piston Identification help
Discussion in 'Engine Topic' started by kyphur, Apr 26, 2008.
  1. kyphur
    kyphur Veteran Member
    145
    Jan 4, 2008
    Huntsville, AL
    Hey guys, I'm having trouble finding information on a set of pistons.
    Under the cap it says TRW above the wrist pin and under it says 262-99 with a J above that. Across the head of the pistons, right below the valve trough it has 336744.
    If anyone can help it would be great, Thanks!
  2. theflash
    11,034
    32
    Feb 27, 2004
    Podunk, CT
    Are you sure those are the correct and the only numbers on the top of the piston?
  3. Kricka
    Kricka Veteran Member Lifetime Gold Member
    417
    Sep 26, 2002
    Skellefte. SWEDEN
    I have that part# on my L-82 pistons from -74. I think the -71 -72 Lt1 and -73 L-82 had them allso. 9:1 cr with 76 cc heads.
  4. kyphur
    145
    Jan 4, 2008
    Huntsville, AL
    Kricka> Yep, those are the exact same pistons out of my 74 Z28 LT. Do you have a link to the part information by chance?
    Thanks man!
  5. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
  6. kyphur
    145
    Jan 4, 2008
    Huntsville, AL
    Yeah, the nastyz28 page that they reference doesn't have my casting number on there. Oh well.
    Though I did find something else in the post that answered another question. Thanks man!
  7. 74RAT
    74RAT Veteran Member
    3,400
    Dec 28, 2003
    ft. stockton,tx,usa
    the old listing from Badger is cast piston replacement number P460. has a 1.550 pin height with 5/64"x5/64"x3/16" ring grooves and the standard .9275 pin diameter. hope it helps.
    andy
