Plastic fly wheel cover
Discussion in 'Transmission & Driveline Topics' started by larrylarry, Apr 29, 2018.
  1. larrylarry
    larrylarry Veteran Member
    1,553
    72
    Dec 22, 2011
    San Antonio Tx
    Bought one of these for my 700r4. It was a major pain in the ass to trim it so the end of the crankshaft wouldn’t rub on it!!!!! I had to slide in & out from under my 78 at least 12 times before I had it right. I used my Dremmel tool with a metal cut off wheel to trim it. The plastic is to thick to cut with a box cutter. I’d used only 2 hex head screws to hold it up, turn on the engine and let the crankshaft beat on it some an take it out an trim. That half round section needs to be cut about 3 ins. lower & the 2 ribs on each side of the round section need to be cut about 2 ins. lower also plus cutting a section out for the starter. I should of took a pic of it when I was done but didn’t. I was to the point of leaving it off. Maybe this will help some one else. 6780543D-4A90-4E3B-8716-1084AF64A04A.jpeg
  2. Twisted_Metal
    27,054
    995
    Better yet... When they get hot, they warp a little and it still might rub.
    I finally took the one off my 2004R because of that issue.
  3. slayer021175666
    slayer021175666 Veteran Member
    1,217
    60
    Feb 29, 2016
    Idaho
    Take it off for good. There is no benefit to having one that I've ever found. I been running without it for 20 years or more. All they do is get in the way, imo.
  4. CorkyE
    10,376
    471
    Same here, haven't used one in (many) years.
  5. 80sz
    80sz Veteran Member
    3,193
    421
    Feb 2, 2014
    Buffalo,n.y.
    Me either, it’s like a lawn mower don’t put your fingers in there! Plus it cooled better, at least in my head
