Polyurethane motor mounts
Discussion in 'Competition Camaros' started by JRausch, Dec 7, 2015.
  1. JRausch
    JRausch New Member
    20
    Jan 29, 2007
    I have an 81 camaro bracket car 427 sbc approx 600 hp runs mid 10's @ 125mph and was wondering if anybody has put polyurethane motor mounts in and how they worked? My problem is my collecter extensions hit the transmission cross member when I whack the throttle or start and shut off the car, still using stock rubber mounts. I've dimpled the extension, but don't want to go any more. (Car was not meant for 3/1/2" exhaust.)
  2. Mike N
    2,609
    420
    Jan 13, 2002
    Spencerport, NY.
    Solid mounts in my 81, roughly the same et's and also a 3 1/2" exhaust. I debated urethane but figured they wouldn't last very long.
  3. JRausch
    JRausch New Member
    20
    Jan 29, 2007
    Which solid mounts did you use? Since you went solid on your motor mounts, what about your trans mount, solid or polyurethane?
  4. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Before switching to motor plates I also ran solids street & strip.
    Was not even close to as bad as everyone said it would be.
    I barely noticed a difference, since the car wasn't very smooth anyway.
    Unless you have a full chassis car like my Pro-Mod, which I use a solid trans mount as the limiter.
    You should NEVER use a solid trans mount in a real car, even with a top notch cage.
    Use an aftermarket poly trans mount and you will be fine, and not eat cases.
    Good luck.
  5. Mike N
    2,609
    420
    Jan 13, 2002
    Spencerport, NY.
    Moroso solid mounts and a stock rubber trans mount.
  6. Bobalos
    Bobalos Veteran Member
    345
    Dec 6, 2005
    X2 worked bitchen for a long time.
    Bob
  7. roeville
    roeville Veteran Member
    1,153
    58
    Oct 9, 2000
    SF East Bay CA
    x3, ran same set up years ago with no problems.
