Pony Car Help
Discussion in 'The BS Topic' started by Bob R, Aug 13, 2014.
  1. Bob R
    Bob R R.I.P 11/20/16 Staff Member
    4,219
    Jan 6, 2000
    Flower Mound, Texas
    Okay I know it's a Mustang, however it's the arch nemesis of the Camaro. My daughter (unknowing to me) sold her car for a nice profit and purchased a 1999 V6 Mustang. (wanted a Camaro) The car is in good shape for it's age but needs Dads (that would be me) help on a few things.
    The major issue is the ABS system. Light is on constantly. Doing a little trouble shooting here and there yields nothing. Was told Autozone could run their anaylzer on it and fault it either to the ABS controller or the independent speed sensors on each wheel. Obviously I was told wrong. They cannot do that, only Ford. So not wanting to go there at this point does anyone know of anyone that can run a diagnostic on the system to confirm what is not working correctly?
    Ford wants close to $800 for the ABS box. Bosch can trade it out for about $200 if I go that route. Speed sensors are about $75 per wheel.
    If anyone has any ideas please let me know. She wants my Z28. She isn't going to get that..... ever
    Thanks in advance guys,
    Bob R
  2. Mike N
    2,753
    527
    Jan 13, 2002
    Spencerport, NY.
    Have you had anyone pull codes yet? Any corner garage or chain shop should have a basic enough scanner that can pull ABS codes.
    Besides, even if Vato Zone could scan ABS I doubt an 02 sensor would fix it. :p
  3. Knuckle Dragger
    14,760
    1,300
    Nov 2, 2002
    Waddell AZ
    Get the code first. There are all kinds of cheap quick fixes on these cars.
  4. 81 Sport Coupe
    81 Sport Coupe Veteran Member
    246
    Nov 27, 2012
    Batavia, NY
    my sister has the 2000 v6 mustang, i would get the codes first, i know colemuffler read mine with no charge. on my sisters mustang the left rear abs sensor wire was stripped. somtimes cleaning them helps because they are magnetic.
  5. Bob R
    4,219
    Jan 6, 2000
    Flower Mound, Texas
    Thanks guys,
    Your the best!
    Bob R
  6. Mike N
    2,753
    527
    Jan 13, 2002
    Spencerport, NY.
    Hey Bob, is the light on all the time or does it come on as soon as the car moves?
  7. Bob R
    4,219
    Jan 6, 2000
    Flower Mound, Texas
    Mike it is on all the time. As soon as you turn the key to start it comes on and stays on.
    Bob
  8. parts_master1
    parts_master1 Veteran Member
    441
    Jun 15, 2011
    Don't let the past remind us of what we are not no
    Basic code scanner will not read PCM bcm or abs codes. You are Hana have to take it to a shop with real equipment. If you spend a bill or two on an accurate diagnosis, it will save you in the long run. Good luck with it.
  9. parts_master1
    441
    Jun 15, 2011
    I just sent a message to a friend in flower mound that might be able to put you in touch with someone. I'll let you know.
  10. Mike N
    2,753
    527
    Jan 13, 2002
    Spencerport, NY.
    I didnt even need to look at your location to know you're close to me, since Cole is a local chain.
