Posi Differential Donor Options?
Discussion in 'Transmission & Driveline Topics' started by MMFS, Oct 9, 2019.
  1. MMFS
    MMFS New Member Gold Member
    14
    Apr 29, 2019
    Austin, TX
    Mostly 80s and early 90s domestic cars and trucks... I do have a 1970 Monte Carlo, a 1963 Mercury Comet and a 1974 Mercury Comet convertible...
  2. big gear head
    big gear head Veteran Member
    6,170
    78
    Jul 30, 2001
    Central City, Ky.
    Does the Monte have a 12 bolt in it?
  3. MMFS
    14
    Apr 29, 2019
    Austin, TX
    Probably, I’ll have to go look...
  4. BonzoHansen
    19,349
    724
    Jun 1, 2005
    Scott from Hamilton, NJ
    Freddie, could there be odd ball S10s with a posi that would work?
    Or g body i suppose, but that rear is too valuable to take the posi
  5. big gear head
    6,170
    78
    Jul 30, 2001
    Central City, Ky.
    All of the S series trucks that had a limited slip differential got the Governor Lock, same as the full size. Yes, the Buick GN and T Type got the same Traction Lock as the Camaro, but as you said, you wouldn't want to split up one of those.
  6. BonzoHansen
    19,349
    724
    Jun 1, 2005
    Some odd ball olds to i think. 442s?
    So trucks and s10 are 8.6s?
  7. MMFS
    14
    Apr 29, 2019
    Austin, TX
    There are a few S10s down there; closest thing I found was a 1987 Caprice Brougham, but it’s not the police package; there may be one of those, but didn’t see it/can’t get to it... There are 3 Ford Police Interceptors that I can see...
  8. Gary S
    22,409
    751
    That '87 Caprice most likely will have a 7.5" rear end in it. Most of the "civilian" models of Caprice and Impala after 1977 have 7.5" rears unless they had posi. My Son has a '77 Impala that came with a 8.5 non-posi, but all the later ones I've had were 7.5". Police and Taxi versions had the heavier duty 8.5" and also were more likely to have posi. A few years ago before the Cash for Clunkers disaster, I found a '79 Caprice in the junk yard with a 8.5" posi, and my Son found another one from a "76 Monte Carlo which ended up in his '77 Impala where it now lives.
  9. big gear head
    6,170
    78
    Jul 30, 2001
    Central City, Ky.
    Most of the S10 rear ends are 7.5, but a few in the '90s and early 2000s got the 8.5/8.6 rear end. All of the truck (S series and full size) 8.5 and 8.6 limited slip differentials were the Governor Lock, which is a bad idea for a performance car. They were barely good enough for a stock truck.
    Yes, there were a few 442s in the 80s that got the 8.5, but they were rare.
    BonzoHansen likes this.
