posi rear end knock when making hard left turns
Discussion in 'Transmission & Driveline Topics' started by stewartlong, Mar 24, 2019.
  1. stewartlong
    stewartlong New Member
    Mar 24, 2019
    I have just finished a frame-off restoration to a 1965 GTO that I had a Z-28 Camaro 12-bolt; 3:36:1 4-spring posi that I got out of a junk yard totally rebuilt and then installed.
    What I am noticing when I make hard left turns (and some right hand turns) there is a knock and shuttering feel go through the car almost like I hearing the wheels can't make up their mind what to do?
    Is this a normal thing for 12-bolt; 3:36:1; 4- spring posi rear ends that are bolted up to a TH400 3-SPEED transmission with a shift kit.
    Do I have something going wrong or is this natural when making a hard 90-degree turn into a parking lot/
    Thanks.
  2. 77 cruiser
    77 cruiser Veteran Member
    532
    23
    Nov 17, 2006
    Frostbite Falls MN
    Did you put the GM additive in it?
  3. stewartlong
    Mar 24, 2019
    When the rear was rebuilt I was there and the good "gorilla snot" was added and then good rear oil but I did not know about any other additive to take care of this turning issue.
    Do you have a brand name or item# or description that I can give the Chevy dealership parts counter guy so I don't look stupid trying to explain all of this?
    Thanks for your reply.
  4. DBS
    DBS Veteran Member
    367
    14
    Sep 24, 2014
    Belzoni MS
    I bought some from o'riley and it worked like a charm. Mine was doing the same thing.
  5. gas and guns
    gas and guns New Member
    24
    12
    Aug 24, 2015
    mi.
    Limited slip friction modifier
  6. big gear head
    big gear head Veteran Member
    6,160
    73
    Jul 30, 2001
    Central City, Ky.
    How did you get a Camaro rear end in a GTO? The rear suspension is completely different and the Camaro rear end doesn't have the mounts for the upper controll arms.
    The GM limited slip oil additive will probably take care of the problem when turning. You will have to give it a little time to start working.
  7. stewartlong
    Mar 24, 2019
    Thanks everyone for your help and I have ordered in one bottle of that friction modifier LIMITED SLIP POSI DIFFERENTIAL GEAR OIL additive plus one of those little hand pumps.
    For DBS: "Did you use just one bottle of the stuff to fix the problem or 2?"
    Again thanks to all I'll let you know how this turns out.
    Stew
  8. tom3
    tom3 Veteran Member
    11,801
    298
    Aug 1, 1999
    ohio
    Had the same problem with my 70 with a factory posi setup. I had changed the lube and put in some aftermarket additive. Was ok when cold but jumped some hot. Drained and refilled with new lube and a single bottle of the real GM additive, been quiet since. Good thing is for that to jump like that you know the clutches are working as they should and not overly worn, I think.
    mallard likes this.
  9. Fbird
    3,720
    533
    Feb 12, 2011
    atlanta, ga
    clutch BITE!!! like getting kicked in the ass sideways while turning....add gm additive then go do some figure 8's......with traction!!! that will work it in...should only take a couple times before it is smooth.
    berg2695 likes this.
