possible eddy carb issues
Discussion in 'High Performance Modifications' started by cutty, Aug 25, 2013.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    maybe its just me not sure so thought id ask lol, got a edelbrock 1406 on my 454 30 over with a edelbrock performer cam and intake with a carb spacer, but seems to be sucking alot of air, you can hear it sucking, i have no leaks,vac is a solid 13 inchs, heres a little video i made of it,could it be carb not big enough or maybe carb spacer? in video sounds like its a bog, but its not i can assure that
    http://www.youtube.com/watch?v=tgFg3WTBYnw&feature=youtu.be
  2. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    You have a worrying about nothing issue.
    Have you heard a stock motor run without it's factory air cleaner assembly?
    They make all kinds of sucking noises.
  3. 5spd540
    12,396
    16
    Sep 19, 2009
    Guyton, GA
    I had a 750 eddy on my 454 that was fairly stock. Yours seems to just be sucking a lot of air it should be fine.
  4. cutty
    342
    Dec 12, 2008
    ontario canada
    ok, wasnt sure, as the quad didnt suck that much air,
