Post up your "big wheeled" cars...AKA...17's or larger AND ADD YOUR BACKSPACING INFO!!!!!
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by CarNDrvr, Mar 9, 2009.
  1. C4Racer
    C4Racer Veteran Member
    652
    118
    Oct 26, 2018
    oh - ya not at all what I'm looking for. I am building a pro-touring style car so I want a matching set of modern summer max performance tires.
  2. aggcamaro74
    aggcamaro74 Member
    64
    Feb 23, 2007
    Found a set of four 17x8s with 5.5 inch backspacing American Racing Daytona wheels and I am wondering if they will work on a 1974 Camaro with 2 inch lowering springs up front and an otherwise stock suspension set up. I appreciate the help!
  3. 8pack
    2,623
    149
    Aug 29, 2007
    Western, MA
    They should. You may need a 1/4" spacer up front. Full disclosure...I have not fit those wheels. My opinion is based on a lot of research.
    A 5.5" backspace seems to be the most you can go without the risk of running into clearance issues. For the rear, if your diff is not centered you might need a spacer on one side or the other. Most people can fit a 9.5" wheel and 275 with little or no mods. Since you are running an 8" wheel you should be good. A 255 would probably be the right tire. I think the rim might be too narrow for a 275 to fit properly but you will have to look that up.
    Some people seem to have no problem with an 8" wheel and 5.5" BS up front. Rubbing on the sway bar seems to be the biggest issue. Like I said above, you can always add a spacer .you may be able to get a 255 up front, but 245 is a safe bet.
    Others will have a different opinion. Just be cautious, when someone tells you they fit a bigger set up on, or any set up, make sure you find out ALL the mods they made to get it to fit...brakes, springs, rear end, tubs, etc. etc.
    Good luck...
    aggcamaro74 likes this.
  4. aggcamaro74
    aggcamaro74 Member
    64
    Feb 23, 2007
    Thank you for the run down I really appreciate it. The price is almost too good to pass up so I just want to make sure it is worth the purchase and possible required work arounds.
  5. 8pack
    2,623
    149
    Aug 29, 2007
    Western, MA
    Don't go only by my recommendation! You might want others to weigh in and do some measurements.
    I have added to my signature a link for the wheel Fitment tool I bought as it keeps coming up .
  6. aggcamaro74
    aggcamaro74 Member
    64
    Feb 23, 2007
    Even better. Thanks again 8pack!
  7. dave@ztech
    3,508
    718
    Mar 27, 2016
    NY
    And before you buy 17 inch rims, look at the limited choices in tires, and getting less to choose from each year, you might want to look for 18 inch rims, just my .02
  8. carr911
    carr911 Veteran Member
    1,870
    412
    Mar 4, 2016
    Tampa, FL
    I haven't had any issues getting great tires in 17"
  9. ZEN357
    ZEN357 Veteran Member
    384
    70
    Feb 12, 2018
  10. C4Racer
    652
    118
    Oct 26, 2018
    17s are available. But very true they are more limited. Especially if you deviate from the common 245/275 split
