Post up your "big wheeled" cars...AKA...17's or larger AND ADD YOUR BACKSPACING INFO!!!!!
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by CarNDrvr, Mar 9, 2009.
  1. boostedRS
    boostedRS New Member
    10
    Oct 19, 2018
    i love this. I right down to the color of your car. I would like those wheels!
  2. Rick Figus
    Rick Figus New Member
    17
    Feb 5, 2019
    Oak Forest, Illinois
  3. Rick Figus
    17
    Feb 5, 2019
    With no modification? Besides rolling the rear fender. No rubbing . It looks awfully tight
  4. UMI Tech
    UMI Tech Member NastyZ28 Sponsor
    60
    33
    Jan 10, 2017
    Central PA
    Wheels look great! Have you tried the rears on the front? We are trying to decide if the fronts will have trouble at 18 x 9.5 with 5.5 BS. On a '71 Trans Am.
  5. C4Racer
    C4Racer Veteran Member
    655
    118
    Oct 26, 2018
    I think that is going to depend on a bunch of things like UCA type, sway bar, camber, ride height. Seems most running 275 run a 5.75-6” bs but 5.5 gives you more swaybar clearance at the expense of potential inner fender issues. Depends on ride height. That hugger orange car is lower than mine is. Seems lower than most.
  6. Ls3rs
    Ls3rs New Member
    23
    8
    Oct 1, 2017
    Just got my 18x10’s mocked up and it’s looking pretty tight. I’m wanting to run a 295/40 but I am concerned that the tire bulge will hit the leaf spring. I could settle for a 285/40 if it would make the setup work. Any opinions on how much the tire will stick out past the rim? I’ve seen 275/35 on a 275 rim but it looked at bit stretched.
  7. C4Racer
    655
    118
    Oct 26, 2018
    What year is the car ? What backspacing did you get?
    I just ordered rocket attack in 18x10 6” bs for a 71.
    I had 295-40-17 before on 17x9.5s with I believe 5.75” bs and they fit just fine. Al stock fender and inner fender.
  8. Ls3rs
    Ls3rs New Member
    23
    8
    Oct 1, 2017
    It’s a 1972, stock fenders and tubs. The backspacing is 6.2 as recommended by Weld Racing. I may try the 285/40 and if it hits then I may have to use a 1/4” spacer, until I can afford the Speedtech torque arm setup and eliminate the leafs
  9. C4Racer
    655
    118
    Oct 26, 2018
    6.2 seems too far in to me. But 285 should fit either way. You can always run a 1/4" spacer.
  10. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,138
    68
    Feb 23, 2009
    San Diego, CA
    XXR 531’s in 18x9.5” with 5.625” of backspacing after using a 1” adapter up front and 18x11” with 5.87” of backspacing after using a 1” adapter. 275/35/18 Falken Azenis RT615K+’s up front and 315/30/18’s in the rear.
    While the rears fit without modification, I beat the seatbelt humps in with a sledgehammer for good measure. The fronts also don’t rub while driving normally around town, but I’m sure they will when autocrossing.
    V8TEC, roadrace2, z28cp and 3 others like this.
