Post up your "big wheeled" cars...AKA...17's or larger AND ADD YOUR BACKSPACING INFO!!!!!
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by CarNDrvr, Mar 9, 2009.
  1. C4Racer
    C4Racer Veteran Member
    655
    118
    Oct 26, 2018
    Should work with either BS
  2. Madiron
    Madiron New Member
    Mar 28, 2019
    Thank you sir
  3. C4Racer
    655
    118
    Oct 26, 2018
    5.5 may even be safer on a later car with the reduced tub clearance.
    I have a 295 on my car and there is tons of room. 5.75” bs effectively. Actually 6” but the the rear is .5” wider or .25” per side. If anything I may still run a .25” spacer which will be like a 5.5” bs on a stock rear.
  4. 79SOMEDAYCamaro
    79SOMEDAYCamaro New Member
    13
    9
    May 27, 2004
    Mcpherson
    Finally got my set of '10 Camaro wheels mounted up on my '79. I'm happy with how it turned out. Fronts are 20" x 8" with 245/35s and the Rears are 20" x 9" with 285/35. I'm running 1.25" adapters on the front and 1.5" adapters on the rear. Also cut one full coil off the front springs to get it to sit where i wanted it.
    sandiego74 likes this.
  5. 70ZED
    70ZED Veteran Member Gold Member
    365
    34
    Jun 21, 2010
    Calgary, Alberta Canada
    Still have them per chance?
  6. 75Maro
    75Maro Veteran Member
    440
    28
    Mar 31, 2008
    Dallas,Tx
    285/35/18
  7. C4Racer
    655
    118
    Oct 26, 2018
    No. Sold them to another member on here who is local to me. They look great on his car !!!
  8. Madiron
    Madiron New Member
    Mar 28, 2019
    any rubbing?
  9. 79SOMEDAYCamaro
    13
    9
    May 27, 2004
    Mcpherson
    If I push it hard yes, the fronts rub right on the outside edge of the inner fender but far enough away from any sharp edges that I'm not concerned. Rears clear no problem. With a stiffer aftermarket suspension I don't think it would be a problem anywhere. Wanted to get it set up on the cheap for now to see if I like it. So now I start planning for better suspension.
    Dcmusch likes this.
  10. Rick Figus
    Rick Figus New Member
    17
    Feb 5, 2019
    Oak Forest, Illinois
    18x7 in front. 18x9 in rear. 275s in back with 225 in front. Goodyear. American Racing rims.
