Post up your "big wheeled" cars...AKA...17's or larger AND ADD YOUR BACKSPACING INFO!!!!!
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by CarNDrvr, Mar 9, 2009.
  1. dutch73camaro
    dutch73camaro Veteran Member
    172
    39
    Jan 7, 2016
    Beverwijk, Netherlands
  2. GoldenOne7710
    4,825
    416
    Jun 23, 2004
    Athens, GA
    If the car in your avatar is your car with those wheels...I can see how it would work. You have your sitting a little higher in the rear, giving clearance so your tires have more room.
    Lots of us are trending towards the pro-tour look where the car sits low all the way around and wheels tuck in the rear....where 4.25 inch backspacing wouldn't work with a 10" wide wheel....not without modifying the fender lip. Yours is probably exactly what your specs sheets say it is.
  3. SPG
    SPG Bumblebee Builder
    361
    62
    Sep 1, 2018
    Sacramento
    yup, whats in my picture is what I'm using, the car use to have 1" lowering blocks, an extra ghetto mounted leaf and the tires rubbed, I had to remove them to go back to stock ride height to fix the issue. I had to roll my fenders though.
  4. mrfleet12
    mrfleet12 Veteran Member
    322
    88
    Aug 8, 2014
    West of Chicago IL
    Thought I'd put this on here previously but can't see that I did..
    US Mags Rambler U121
    18 x 8 - 4.5 245 - 40 - 18
    18 x 9.5 - 5.5 275 - 40 - 18
  5. Anthony Burgos
    Anthony Burgos New Member
    Jan 22, 2019
    Colorado
    You state if you went went with 40's in the rear next time.....if you DID go with 40's in the rear, would that backspacing have changed on the wheel? or fender contact with tire? Thanks
  6. 70ZED
    70ZED Veteran Member Gold Member
    368
    34
    Jun 21, 2010
    Calgary, Alberta Canada
    Thanks for that !
    ESR SR12s:
    F: 18"x9.5" / +22mm/6.11" - 12mm/.47" spacer = 5.64" effective backspace / 275/35R18
    R: 18"x10.5" / +22mm/6.61"- 20mm/.79" spacer = 5.82" effective backspace / 315/30R18
    Haven't driven the car, but see this thread for similar specs. I haven't put any camber in the front yet, but will do -1* or -1.5*, and it should clear fine even after I lower it a bit (and use button-head Torx bolts for inner fender). I cut the inner lip off and slightly flared the rear wheel openings - the rear will settle a bit more once the car is complete and after some time as the (PTFB Comp) leafs are brand new.
    I really wanted 315 out back. Worst case, I'll move the fronts to the rear and get 8.5" / 245 or 255 for the front, which should fit no worries at all, even slammed.[/QUOTE]
    2000z and $ Mike 70 Z-28 like this.
  7. Rayden2009
    Rayden2009 Veteran Member Gold Member
    111
    14
    May 12, 2016
    Calgary AB
    Backspacing won't change. The tire will be a little taller. I know of people running 275/18/40 with a 5.75” BS with no issues. 285/18/40 will be a little more risky, but I hear its being done too. 5.75” BS on a 10” rim seems to be the sweet spot.
  8. 8pack
    2,621
    149
    Aug 29, 2007
    Western, MA
    You really have to be careful. I am sure that generally you are right, but:
    • Are you running a stock rear end
    • Is the rear perfectly centered or slightly offset which is common. This will result in rubbli g on one side but not the other.
    • Are you running an e-brake. Stock drums or discs? On aftermarket calipers? TA Disc brakes?
    • How much is the car lowered which is a big variable.
    Just saying that you really can't go by anyone one person's experience or even groups if people unless you know you have exactly the same set up otherwise you will run into issues.
    BTW, I do agree a 275 tire should be no problem but I think the 5.75 backspace will give some people trouble on the inboard side with certain e-brake set ups and 5.5" is a safer bet but you could wind up with an outboard issue if your rear is not centered.
    dave@ztech likes this.
  9. JUNKYARD AUTOCROSSER
    JUNKYARD AUTOCROSSER New Member
    Nov 16, 2009
    Los Angeles, CA
    I run 18x10 wheels in the front with 6" backspacing. Tire size is 275x 35x18 (modified inner fender and use Global West control arms)
    I run 18x 11 wheels in the rear with 6" backspacing. Tire size is 315x30z18 with no wheel tubs
    17x10 will work in the front with 6" backspacing . Tire size is 275x40x17
    17x11 will work in the rear with 6" backspacing . Tire size is 315x35x17 with no wheel tubs
    $ Mike 70 Z-28 likes this.
  10. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    983
    23
    Nov 7, 2002
    New York, NY
    JUNKYARD.. did you modify the inner fender lip or the seatbelt hump to fit 315 30 18 with no wheel tubs
