Post Your LS & 6L80E Swap PICS
Discussion in 'High Tech Retrofits' started by gmagno, Feb 13, 2012.
  1. gmagno
    gmagno Veteran Member
    282
    Jan 16, 2010
    Montgomery, TX
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
  3. gmagno
    282
    Jan 16, 2010
    Montgomery, TX
    I know how big it is, I did not forget my old thread and just want to see if there are any others attempting this so we can all help each other through the process. After all, this is a forum, isn't it?
  4. camcojb
    camcojb Veteran Member Lifetime Gold Member
    2,599
    Jan 10, 2000
    Wilton, Ca. USA
    well, this is the perfect way to get help............ :screwup:
  5. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    I don't think Ace was trying to be rude there are many discussions and usually a simple search will answer your questions otherwise the forum will get clogged up with repetitive threads.
  6. gmagno
    282
    Jan 16, 2010
    Montgomery, TX
    I understand and did not take it that way. I realize everyone thinks I am stupid for attempting this and they are all entitled to their opinions.
  7. BonzoHansen
    19,302
    703
    Jun 1, 2005
    Scott from Hamilton, NJ
    I'm not sure I've seen a 6L80E in a 2nd gen for the reasons I listed in your last thread. Has anyone seen one yet?
  8. camcojb
    2,599
    Jan 10, 2000
    Wilton, Ca. USA
    I don't think it's stupid, assuming you can get it in there with enough ground clearance. By those pics in the other thread it looks like the stock oil pan is way too low; maybe it's the angle of the pic.
    My 4L80E in a 64 Chevelle required a stock flat oil pan to not have the pan well below the frame. Every aftermarket pan was too low. Do they make a much shorter pan for those trannies? The stock one looks like an engine oil pan, it's so deep.
  9. BonzoHansen
    19,302
    703
    Jun 1, 2005
    That is what I see and hear too, jody. the builders I asked at sema all had the same fear using that trans in a low vehicle.
    Gmango, you might have to be a trailblazer.
  10. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I wasn't saying that dude. :confused:
    I forget about my own threads sometimes. I found it, and posted it for you.
    I think if you can make it happen, that would be an awesome accomplishment.
