Powder coated front and rear sway bars.
Discussion in '1970 - 1973 Specific' started by john Gialanella, Jan 26, 2019.
  1. john Gialanella
    john Gialanella Veteran Member
    282
    12
    Oct 15, 2008
    Bloomfield N.J.
    Do powdered coated sway bars hold up after a few years. I kept my original front and rear sway bars in the attic, but bought larger powdered coated bars. Does the powdered coating hold up after a few years. The car is outside with car cover, and is driven once a week for 20 miles so that moisture does not stay on car.. But a front bar I bought a few years ago which was suppose to be powdered coated lost about half the coating. I was pretty sure it was powdered coated. Any info would be welcomed.
    Thanks John.
  2. 351maverick
    351maverick Veteran Member
    3,662
    428
    Aug 11, 2010
    erie, PA
    powder coating is basically a melted plastic coating - it's so tough & flexible it should last forever
  3. Gary S
    22,662
    836
    My experience with powder coating is that it will last about as long as decent paint. I installed an iron fence some years ago. It was powder coated. The coating started flaking off after a couple of years. I removed the loose powder coating and painted with Rustoleum. The Rustoleum flakes off too after time, but it actually lasts a bit longer than the original powder coating did.
  4. CAMeeks
    CAMeeks Veteran Member
    694
    37
    Jan 5, 2014
    Deer Park, TX
    Also depends on prep of the piece and quality of coating.
    carr911 and 70ZED like this.
  5. carr911
    carr911 Veteran Member
    1,886
    422
    Mar 4, 2016
    Tampa, FL
    and then what elements it is put into. OP is from NJ and I'm not sure what they put on the roads up there in the winter
  6. john Gialanella
    282
    12
    Oct 15, 2008
    Bloomfield N.J.
    Thanks to all of you for the responses.
    John.
  7. Zspoiler
    Zspoiler Veteran Member
    3,312
    273
    May 6, 2012
    Federal Way, Washington
    I used VHT Chassis epoxy on my sway bars .It has a similiar 'look" of powder coating but can be "touched up" it needed. And I plenty of both types on my car.
