Primary and Secondary Idle Mixture Screws, 4 same or only 2
Discussion in 'Engine Topic' started by 71Camaro707, Dec 6, 2018.
  1. 71Camaro707
    71Camaro707 New Member
    Nov 13, 2018
    When I bought my car I found that the Holley 4150 4bbl secondary idle mixtures screws were all the way closed [all the way clockwise] and only the primary idle mixtures screws were opened. I figured all the the screws should be the same amount open to equal the air fuel ratio withing the complete intake manifold [Edelbrock Victor Jr]. So should I adjusted all 4 or readjust to just the primary?
  2. CorkyE
    10,453
    508
  3. 71Camaro707
    Nov 13, 2018
    Thank you.
  4. 1980RS
    1980RS Veteran Member
    3,547
    649
    Jun 17, 2006
    MN
    Single plane intakes are not as touchy about 2 or 4 corner idle as dual planes. Remember to set the transfer slot no more than .020 looking at the carb overturned, too far open make the engine run pig rich and the screws might not do anything.
