Pro Comp gas gauge not working correctly
Discussion in 'Gauge Marks' started by ZoSoIV, Sep 16, 2018.
  1. ZoSoIV
    ZoSoIV New Member
    12
    Sep 16, 2018
    hey guys just bought a 1970 Z-28 , RS on the resto they used Pro Comp gauges and the gas gauge isn’t working correctly ... when full it shows just over a half tank and empty it shows around a quarter tank ... I’m trying to pin down if it’s the gauge or the gas tank float ... what should I look at first ? Thanks
  2. dave@ztech
    2,359
    361
    Mar 27, 2016
    NY
    Check the voltage, and see if the correct voltage is at the gauge , if it is then the junk in the trunk/tank is acting up
  3. ZoSoIV
    ZoSoIV New Member
    12
    Sep 16, 2018
    Ok thanks
  4. Twisted_Metal
    26,429
    677
    The gauge is an ohm meter.
    It measures resistance in the circuit through the sending unit.
    It may simply be a mismatch between the gauge and sending unit resistance range.
    Try to find out the model of the gauge to find its intended ohm range.
    If I remember correctly... the sending unit should be 90 Ohms full and 0 Ohms empty.
  5. ZoSoIV
    ZoSoIV New Member
    12
    Sep 16, 2018
    Thanks
