Progress on the 72'Camaro
Discussion in 'Project Progress' started by Throttle, Feb 26, 2008.
  1. sovain
    sovain Veteran Member
    675
    Sep 12, 2008
    cambridge,ontario
    car sounds awsome.
  2. Throttle
    Throttle Veteran Member Gold Member
    1,342
    Feb 2, 2002
    Dripping Springs ,Texas........USA
    Installed the hood pins, and nee horn parts. Also cleaned up the factory steering wheel.
  3. Throttle
    1,342
    Feb 2, 2002
  4. Tokyo Torquer3
    Tokyo Torquer3 Veteran Member
    2,187
    Oct 14, 2003
    NJ
    whose hood pins did you use?
  5. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,553
    18
    Feb 11, 2009
    Kentucky
    Looking great throttle
  6. Throttle
    1,342
    Feb 2, 2002
  7. Thunderkyss
    Thunderkyss Veteran Member
    222
    Sep 16, 2012
    Texas
    What exactly are you doing here? What is the process called? Are you welding rods into the dents so you can pull them out?
    Thanks in advance for any reply. Great job on the car.
  8. Throttle
    1,342
    Feb 2, 2002
    Yeah, that is what Im doing.. The person that owned it before me must of had a Low wall they parked up against because the front and rear where dented in at the same height..
  9. 78LT383
    78LT383 Veteran Member Lifetime Gold Member
    1,779
    Jul 12, 2005
    Princeville, IL USA
    How do you rust proof the back side of that panel after welding all of those pins to it?
  10. Throttle
    1,342
    Feb 2, 2002
    You don't, that one of the few issues with doing that on this type of car... It had to be done though.
