Project code name - Never Satisfied
Discussion in 'Project Progress' started by 1981LT1, Jan 7, 2017.
Shaved Door Handles?
Poll closed Oct 16, 2017.
  1. Yes
    1 vote(s)
    25.0%
  2. No
    3 vote(s)
    75.0%
  1. 1981LT1
    1981LT1 Veteran Member Lifetime Gold Member
    528
    83
    Dec 15, 2004
    San Antonio, Tx, USA
    One of the few things I have put off until now is the trim clips for the glass. The new quarter panel didn't come with the studs so I have to find a way to attache the clips. I saw on tv several years ago some small sealant coated self tapping screws but I can't find them online. Does anybody know what I can use? Sure this is not a new thing and somebody has figured this out before.
  2. thesalboy
    thesalboy Veteran Member
    345
    110
    Mar 25, 2017
    Los Angeles, CA
    Belden Speed & Engineering sells screw-in and rivet-in trim studs (scroll to the price list at the bottom). I recall finding screw-ins on Amazon too. Don't recall seeing them pre-loaded with sealant anywhere.
    Check out my build thread for how I adapted my HF stud welder to weld on trim studs.
  3. JohnL71RS
    JohnL71RS Veteran Member
    1,656
    42
    Apr 12, 2010
    Marrero, LA
    i also bought some from Classic or another vendor. they were screw in studs for a 67-69 camaro. The only issue with mine was, the studs were too long and the back glass wouldn't go in. it was only off by 1/16" to 1/8". I ended up pop riveting them in.
    BTW, i still have the screw in studs.
  4. 1981LT1
    528
    83
    Dec 15, 2004
    The weather has been cooperating and now that the holidays are over, I have been able to work on the rear bumper. I spent a couple of hours sanding down to the urethane and then realized I didn't have any adhesion promoter for the paint. After a trip to the paint store, and a quart of DuPont 2K Urethane primer, I was ready to finish the job. Here is the 600 grit wet sanded result ready to paint. I have already dusted over the bare urethane so the paint covers easier. It will be red tomorrow after work!
  5. 1981LT1
    528
    83
    Dec 15, 2004
    I cleaned out my storage unit over this past week and I have decided to sell some parts I know I won't need any more. Check out my listing here.
  6. 1981LT1
    528
    83
    Dec 15, 2004
    I was able to repaint my intake when I painted my rear bumper. I also got my fender braces painted as well. I don't have any pics of the rear bumper yet but it is installed and looks amazing. I switched from a 1.3mm fluid tip to a 1.5mm and everything is flowing much better out of my gun now. I really wish I would have done that a long time ago.
  7. 1981LT1
    528
    83
    Dec 15, 2004
    I also had a friend bend me up some scrap aluminum to cover my wire junction on the frame rail.
    BEFORE:
    AFTER:
  8. dave@ztech
    3,394
    701
    Mar 27, 2016
    NY
    Nice progress, looks so clean!
  9. 1981LT1
    528
    83
    Dec 15, 2004
    I've had plenty of opportunities to take pictures of the rear bumper installed but I keep forgetting (but you can see it in the background of the picture below). I have however been able to get the front bumper 99% sanded. I still need to get inside the headlight buckets and the grill areas by hand but that shouldn't be too hard. I have also removed the master cylinder and hydroboost unit and they have been primed with etching primer. Once I prime the front bumper I'll get those in primer as well.
  10. dave@ztech
    3,394
    701
    Mar 27, 2016
    NY
    It's starting to really come together, looks great!!
