Project Deadpool
Discussion in 'Project Progress' started by 70Chev, Jan 1, 2015.
  1. 70Chev
    70Chev Veteran Member
    244
    45
    Oct 21, 2012
    Brisbane, Australia
    So, I've been unimpressed with my Holley 600 vac secondary carby since the day I got the car. Considering a tune is in excess of $500 nowadays I have been looking for a while now at the throttle body fuel injection systems that are available and have been on the market for some time now.
    So, I bit the bullet and sprung for the Go Efi 8 kit by FiTech. Can handle up to 800HP which will be more than enough for my application (for now [​IMG]), and give me some room for future developments.
    Will be doing the install in a couple of weeks so I'll post up some photos and comments on how it goes if anyone is interested.
    Darren
    71RSLS likes this.
  2. MP81
    MP81 Veteran Member
    324
    10
    Oct 10, 2016
    Washington Township, MI
    Please do, I've been looking at this myself - especially if I decide to do heads and cam on the little 305 to hold me over until the LS swap down the road.
    A friend of mine has an '84 Scottsdale with a 305 and its gotten to the point where he crossed the point of no return and screwed his carb up enough the truck won't run properly. He bought the FITech and is installing it on that, and hopefully will solve the issues he's had for so long.
  3. Lars_2Gen
    Lars_2Gen Veteran Member
    644
    168
    Dec 29, 2017
    Fullerton, CA
    I'd also like to see updates and progress on the Fitech. I have a new Carter AFB going on my 327 now, but if I have much trouble tuning it, I will probably just make the jump to EFI.
  4. 70Chev
    244
    45
    Oct 21, 2012
    Brisbane, Australia
    So, I started the first bit of work on the fuel injection install on the weekend. I installed the surge tank/fuel pump. The tank/pump gets fed from the original manual fuel pump and has an electric pump inside to increase the fuel pressure that is then fed to the FI throttle body. This way I didn't have to modify my tank or fuel lines or mount an inline fuel pump.
    I had previously relocated the battery to the boot and was looking for an un-intrusive place to locate the surge tank. I decided to cut a hole in the area where the battery used to be and to mount the surge tank with the bottom half located through the hole. That way, it is out of the way and still allows free flow of air into the cold air induction intake. Have done as much pre-wiring and fuel hose routing as possible and will finish the install off next weekend.
    Will post up more when I finish the install next weekend.
    Darren
    71RSLS likes this.
