Project Old Soul 71 build
Discussion in 'Project Progress' started by C4Racer, Oct 26, 2018.
  1. C4Racer
    C4Racer Veteran Member
    633
    107
    Oct 26, 2018
    took another drive this AM back behind my house deep into the country. Car performed great - handling and steering is incredible for a car of this vintage. Love the trans with this motor too!
    71RSLS likes this.
  2. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    962
    18
    Nov 7, 2002
    New York, NY
    NICE!!! LOOKS GOOD . A+A+
  3. 70ZED
    70ZED Veteran Member Gold Member
    360
    32
    Jun 21, 2010
    Calgary, Alberta Canada
    Great build all around ! Did you go 18x 10 6 BS all around ? I'm trying to figure out what rim spec you used on the front ?
  4. C4Racer
    633
    107
    Oct 26, 2018
    Correct. 18x10 6” bs all around.
    Tires 275/35/18 front
    295/35/18 rear
    No spacer rear but the rear end is 5/8” wider than stock. So about .25” per side. Equivalent to 5.75” bs
    Have not rolled fenders or banged in seatbelt humps.
    On front currently running .25” spacers. Only needed to clear the DSE upper control arms on full lock the wheel hit the upper ball joint area. Could have just made clearance with a grinder to the UCA but I like the wider track looks anyway so for now running the spacers.
    Nitto NT05 tires.
  5. 76z28
    76z28 Veteran Member
    1,982
    42
    Jun 29, 2009
    bakersfield
    Did you need to remove that much of the tunnel? Or did you just want extra space around it?
  6. 76z28
    1,982
    42
    Jun 29, 2009
    bakersfield
    Also, what's your overall impression of the transmission?
    And where are you in CA? We might be able to meet up some time! Your car looks awesome!
  7. SPG
    SPG Bumblebee Builder
    312
    47
    Sep 1, 2018
    Sacramento
    Looks like he lives around mt diablo...which is a fairways away from bakersfield haha (actually found my car at mt diablo in a barn)
  8. C4Racer
    633
    107
    Oct 26, 2018
    No I’m in San Jose.
    And yes you do need to remove a fair amount of the tunnel to get a good engine and driveline angle. And on my car the motor mounts are lower than stock which helps driveline angle. There is a vent tube that hits the tunnel pretty far up the trans so that is why you have cut pretty far up. Doesn’t really matter how much tunnel you cut anyway since the replacement section covers it all anyway.
    It’s a great transmission. Pairs as well with this carbed 406 as it does with a stock LT1 in my 2016. Same trans. I have a lot of seat time so far in the 2016. Anyway nothing bad to say about this trans. Very similar to the Transaxle version in the C5-6 as well and I’ve had 3 of those.
  9. SPG
    312
    47
    Sep 1, 2018
    Sacramento
    eh, close enough lol
  10. 76z28
    1,982
    42
    Jun 29, 2009
    bakersfield
    What mounts are you running?
    What are your angles?
