Pulling motor
Discussion in 'Engine Topic' started by C4Racer, Jan 11, 2019.
  1. C4Racer
    C4Racer Veteran Member
    385
    49
    Oct 26, 2018
    so somebody told me the front grill and radiator assembly pops right off on these cars. I’ve been working for about an hour so far and starting to realize that just doesn’t seem true. Seems a major pain to get it off.
    I was doing that to give me a straight shot to install motor and transmission in one shot. T56 install.
    Is there another way?
    Can you use one of those tilt thingys to get the motor and trans in over the front bumper / grill assembly ?
    Seems like I am tripling the time and effort by removing the front body and then if I don’t line it up right wil have to bring to body shop.
    Body panels and installation are not my specialty!!
  2. BonzoHansen
    18,988
    576
    Jun 1, 2005
    Scott from Hamilton, NJ
    SBC/T56 here. I installed the engine first with clutch all setup, then installed the trans.
    T56 is a big trans
  3. turbobuick
    turbobuick Member
    60
    16
    Nov 24, 2018
    Bonzo, is your small
    Block external balance? What dlywhe did you use? Is it a lt1 t56? I have lt1 t56 for my 454 looking for proper flywheel.
  4. C4Racer
    385
    49
    Oct 26, 2018
    Ya maybe mock it up to make sure trans mates ok out of car and then install without trans. Should be ok to have bellhousing and all contents on the motor when it goes back in eh?
  5. Twisted_Metal
    26,346
    634
    Put the engine in over the fender and mate the transmission to it from beneath the car.
    It can be done in one shot (without the front being disassembled) but it's not easy as the combination is quite heavy and it depends upon how your engine hoist is constructed and where your jack stands are positioned.
  6. BonzoHansen
    18,988
    576
    Jun 1, 2005
    No, it's internal 1pc block. I think you need the same FW a 2pc rms block would use, i don't know the part number. woody does, search the trans section for his posts
  7. BonzoHansen
    18,988
    576
    Jun 1, 2005
    I did it with the bell off, but clutch on and I dialed in the bell before as well.
  8. C4Racer
    385
    49
    Oct 26, 2018
    Any reason bell off? I was thinking bell on would be better. But it’s not hard to put on under the car of clearance is a problem getting motor in place with it on.
  9. BonzoHansen
    18,988
    576
    Jun 1, 2005
    I was fighting poly motor mounts and the clearance helped. damn things just would not line up lol
  10. C4Racer
    385
    49
    Oct 26, 2018
    Oh. Man. I’ll use solid.
